Old 06-12-2014, 05:39 PM   #1
crowdaddy
crowdaddy's Avatar
1964 stepside c10 230 inline six
First off, hello to anyone that reads this, and thank you in advance. My adventure in truckworld started a month ago after rescuing and partly fixing this wonderful old truck. It is still burning off old varnish but is better than it was. It has a noisy manifold and or exhaust leak maybe more. I'm underaverage as a mechanic, and will not do this part. How much can I expect to pay for a new exhaust, (manifold, and or seals in the area where the pipes hook to the block)?
I think this is where the noise is from.
crowdaddy is offline   Reply With Quote
Old 06-12-2014, 07:06 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1964 stepside c10 230 inline six
You can't buy repro stock intakes but you can buy repro exhaust manifolds from LMC, or Truck and Car shop. Napa sells the intake/exhaust manifold gasket...probably would be a good idea to purchase one..and also make sure your stud bolts for the manifolds are nice an snug.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-13-2014, 12:15 PM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
If the exhaust manifold is leaking at the head, I would take it off, take it to a machine shop, and have it fly-cut so the face is flat.
In my opinion, a re-surfaced stock manifold is better quality than a replacement one.
If the manifold is cracked elsewhere, I'd consider having a good cast iron welder fix it.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
