Old 06-12-2014, 06:34 PM   #1
IntegratedTJ
IntegratedTJ's Avatar
Door Lock Not Behaving Itself.. Help?
Hey there guys. Haven't posted in a while. I've got a '72 c10 and was wondering if anyone knew how I could fix my driver side door lock? The passenger side works fine as it should, however the driver side never wants to lock for me. Never. When I push on the button, it feels like it has maybe bent? It won't go down and I don't want to REALLY force it (I've put a considerable amount of force on it.) for fear of it breaking further. I don't know where to start my troubleshooting for a bent part? Or something is rusted maybe? I know nothing about how door locks work and was hoping someone could enlighten me?
IntegratedTJ is offline   Reply With Quote
Old 06-12-2014, 07:59 PM   #2
TacBlade
Re: Door Lock Not Behaving Itself.. Help?
You can get the lock part out in a few minutes. I would take it out and spray the crap out of it with WD40 and work it till its nice and loose! I dought the rods are bent as little as they move.
TacBlade is offline   Reply With Quote
Old 06-12-2014, 08:15 PM   #3
IntegratedTJ
Thanks man. Any pointers on taking out the lock part?
Old 06-12-2014, 09:06 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I don't know if you are aware of it or not but on these trucks you can't push the button down and close the door to lock it you have to lock it from the outside with the key....
If you roll the window all the way down you can see the lock parts if you shine a strong light down inside the door behind the window.
Like TacBlade said spray the crap out of it down through that opening, but I wouldn't use WD-40, Use PB blaster or any other GOOD penetrating oil.
LockDoc
Leon
Old 06-12-2014, 09:12 PM   #5
IntegratedTJ
LockDoc
I'm aware of that. I meant that the lock does not push down at all. And thanks.
Old 06-12-2014, 09:14 PM   #6
LockDoc
LockDoc's Avatar
No problem... I added to my post above.
LockDoc
Leon
Old 06-12-2014, 09:16 PM   #7
IntegratedTJ
LockDoc
Thanks. And I use PB Blaster or Liquid Wrench. Thanks again
Old 06-12-2014, 09:55 PM   #8
loom34432
loom34432's Avatar
Try pushing the door closed while locking; I use my knee to gently push on the door and then lock. Something is worn out a little!
72 C10 350/TH350
loom34432 is offline   Reply With Quote
Old 06-12-2014, 09:58 PM   #9
IntegratedTJ
I mean it wont even push down when the door is open
