06-12-2014, 07:12 PM | #1 |
knock sensor question
so i ran my codes today just for giggles and what not, i knew i had a issues with o2 sensors (they where on the manifolds i got from the boneyard and changed them out today) but i got a code for a knock sensor, what does it do? is it important to change out? and i also i got a low temp sensor code whats this from?
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
06-12-2014, 07:34 PM | #2 |
Re: knock sensor question
Code numbers please.
06-12-2014, 07:38 PM | #3 |
P0128,0135,0155,0327, and 0332
Just a few codes lol
06-12-2014, 08:01 PM | #4 |
P0128....Change thermostat, Use the correct temp AC Delco thermostat.
P0135, P0155....Bank 1&2 O2 heater circuits, Did new O2's fix this? P0332, P0327... 1. Disconnect the two pin connector on top of the intake, it has a Light Blue wire & a Dark Blue wire. 2. Ohm each wire to ground. Should have resistance between 93K-107K ohms for each wire. 3. If not in specification, remove the intake manifold and check the connections and wiring to the Knock Sensors (KS). 4. Check for water down in the holes where the KS's are. Knock sensors play a major role in controlling ignition timing. |
06-12-2014, 08:11 PM | #5 | |
so the ks's are under the intake?
06-12-2014, 08:18 PM | #6 |
Yes, Under the intake., Is the KS jumper harness plugged to the engine function harness?
06-12-2014, 08:20 PM | #7 |
ummmmm......IDK...ill go look lol
06-12-2014, 08:24 PM | #8 |
What am I looking for? Everything that's suppose to be hooked up is to my knowledge, no in plugged connectors
06-12-2014, 08:31 PM | #9 |
Near the back of the intake.
06-13-2014, 01:12 AM | #10 |
Knock sensors play a major role in controlling ignition timing.[/QUOTE] Ohm each wire to ground. Should have resistance between 93K-107K ohms for each wire. Plug that one into memory.........................or where to find it when I need to know!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-13-2014, 03:33 PM | #11 |
i reset the codes and unhooked the battery, and after changing the o2's the only two codes are 0128 and 0332
06-13-2014, 04:08 PM | #12 |
meowMEOWmeowMEOW
128 is the coolant operating temp code. Either the coolant temp sensor is wacked/miswired, or its possible that your tstat is stuck open.
06-13-2014, 04:16 PM | #13 |
I'm going to pick up a new thermostat today sometime or tomorrow
06-13-2014, 07:12 PM | #14 |
meowMEOWmeowMEOW
you can also just whack it with a stick or use a pencil torch to try and heat it up. They can get stuck if they sat with that dexcool in them if it got gooey.
06-13-2014, 07:16 PM | #15 |
I like your way of thinking...even if you ain't 65 balding fat and living in the parents basement lol
06-29-2014, 02:23 PM | #16 |
well with changing my water pump and dry driving weather i dont have any knock sensor codes...after the water pump change all the codes went away...kinda stoked...must have had some condensation in there
