06-12-2014, 10:02 PM | #1 |
Mounting AD cab on 10 with Jeff's mounts - questions
HI,
Been trying to accumulate the exact info I eed to use Jeff's mounts for my 51 on s10. Couldnt find the exact info I needed so hope someone could assist. 1. Mounting placement of front mount is two inches forward of oblong hole (correct?) What about rear cab mount position? 2. Has anyone used Jeffs template and has a specific measure on how high the truck sits off ground...say front fenders? Ive seen varying photos/info but looking to see if these are used just like in template what I can expect it to look like with a good sized wheel of 17" or larger. Has anyone modified Jeffs mounts to make the cab sit lower? 3. is it needed to use the s10 body round mounts with these mounts? 4. Can the mounts be bolted to frame or suggested to weld? thanks so much! KL |
06-13-2014, 11:58 AM | #2 |
Re: Mounting AD cab on 10 with Jeff's mounts - questions
I thought he put it all in his build thread as he detailed it pretty good. Maybe we can make enough noise and wake him up and see what he says. It might not hurt to send him a pm and see what he says too.
