Old 06-13-2014, 09:04 AM   #1
dodgiesdad
dodgiesdad's Avatar
Parking brake for a 65 and 66 K-10
Does anyone have picture of the stock parking brake lever mechanism for a 65 and or a 66 K-10. This is the part that is under the bed and splits the force from the one cable from the lever under the steering wheel to two, one going to each wheel.
I am trying to recreate that in mine. When I sandblasted mine I discovered the (F)-word stamped in it and according to the reproduction cable manufacturer my cables are about 10" shorter than stock.
Thanks.
dodgiesdad is offline   Reply With Quote
Old 06-13-2014, 10:06 AM   #2
bhc41051
bhc41051's Avatar
Re: Parking brake for a 65 and 66 K-10
Mine is a work in progress, I'm looking for a new spring. I think your brake cables are different lengths depending on the wheel base of your truck.
bhc41051 is offline   Reply With Quote
Old 06-13-2014, 10:43 AM   #3
1963c-10
1963c-10's Avatar
Is the 65 a manual or auto? There are 2 different crossmembers for the parking brake assembly on the 2wd trucks.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-13-2014, 10:54 AM   #4
padresag
there were no a/trans in 4 x 4 in these years and the e/brake setup pictured is the right one for the application
ron
padresag is offline   Reply With Quote
Old 06-13-2014, 11:11 AM   #5
1963c-10
1963c-10's Avatar
ron
I must have read the title wrong....though he needed a 65 c-10 and 66 k-10 pictures.....
Old 06-13-2014, 11:19 AM   #6
dodgiesdad
dodgiesdad's Avatar
Thanks bhc41051 that is exactly the view I was looking for. You picture is worth a 1000 words. Now I need to find, make or modify a few things. Have you found a supplier of e-brake cables for the 4x4? I have only found Inline Tube.
Old 06-13-2014, 12:48 PM   #7
61K10
61K10's Avatar
bought mine from inline tube fit perfect. ck on e-bay, they have them listed in stainless cheaper than i paid for my steel ones.
thanks bhc for the pic. I didn't have the spring or the little bracket the spring hooks onto.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-13-2014, 01:57 PM   #8
bhc41051
bhc41051's Avatar
Yeah Inline tube is the way to go for the cables. I've been looking for a spring for awhile. I found one online but you have to order six to make their $40 minimum. It looks like you guys need one as well. so I went ahead an ordered them. I'll let you know when I get them.
Old 06-13-2014, 09:14 PM   #9
Woogeroo
60-66 FAQ Index
Brakes
-W
Woogeroo is offline   Reply With Quote
