Old 06-14-2014, 11:19 AM   #1
B_derK20
Hydro boost swap trouble
I'm in the middle of swapping my '83 K20 to hydroboost and I'm now stuck. My booster is from an '82 K30 and I got a new master and all new hoses for the same '82 model year. My problem is that my hoses are all the o-ring style on both ends but my steering box looks like this picture. The high pressure port is 16mms flare style. The o-ring hose won't thread into it. Do I have the wrong steering box? I have an '88 V30 with hydroboost parts truck that I could take the box off of but I didn't want to tear it out if I wasn't sure it was going to work. Can someone help me out?
B_derK20 is offline   Reply With Quote
Old 06-15-2014, 12:45 AM   #2
B_derK20
Re: Hydro boost swap trouble
After beating my head against the wall all day, I determined that I don't have some mutant steering box after all. It's an '83 so it has to be all metric because the return hose is the o-ring type. Apparently there are tap in inserts that convert the o-ring style port to a inverted flare type. That's what it looks like is in the pressure port. Now I have to figure out how to get the stupid thing out. Does anyone have any ideas on how to get it out?
Old 06-15-2014, 01:50 AM   #3
jeffro308
Try at your own risk but I'd find a punch that will fit in the insert and pry in a circular motion until it comes loose.
Alternately you can re-flare the new hose. Just don't forget to put the correct nut on before flaring.
jeffro308 is offline   Reply With Quote
Old 05-12-2015, 02:03 AM   #4
slimneverdies
slimneverdies's Avatar
I'm trying to make some braided stainless steel lines for my hydroboost but I believe that I bought the wrong fittings. I have 16mm and 18mm to 6an fittings but the 6an to 3/8 seems to fit. Where can I get a 6an to 7/16 fitting? I've searched everywhere and can't find a set...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 05-13-2015, 08:57 AM   #5
v30crewcab
v30crewcab's Avatar
prob need to find a screw to thread into it, and some vicegrips to pull it out.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-03-2016, 11:45 PM   #6
swissarmychainsaw
Did you ever get your HB sorted out?
swissarmychainsaw is offline   Reply With Quote
Old 09-04-2016, 12:38 PM   #7
B_derK20
Yes. I did just was suggested and used a small punch and kinda just used a circular motion and it walked right out. The new hose then threaded right in. The only thing now is I'm not really impressed with the hydro boost brakeing action. Even with a new pump and booster the pedal seems ultra firm and doesn't seem to stop any better than with the vacuum setup.
