![]() Join Date: Mar 2014
Converter Stall Speed - What Do You Run
Have a 66 C10 step side with a 300 HP 350 with 700r4 and 3.08 rear gears. I'm a tried and true 4 speed guy but the wife wants to drive this so you know the deal.....compromise = automatic.
Can anyone recommend what level of stall converter would be best with this combo? Not looking for a race unit but daily driver combo with decent manners. Folks I have talked to are all over the place 1500 to 3000 and up stall speed. What do some of you run with your combos? |
![]() Join Date: May 2012
Re: Converter Stall Speed - What Do You Run
Go with a 10" ,they all stall a little different based on motor and gearing.!! 10" should put you in the 2500 - 3000 range,remember that does not mean it leaves the red light at that rpm.True stall speed is if you had a great set of brakes that would hold ,the rpm it starts loading the motor or pulling it down would be the true stall of any converter.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
Moderator
![]() Join Date: Jul 2006
355/700r4/3:73 here. I run a factory s10 4.3L converter which has advertised stall of 2200, and will flash to 2800. They have the highest stall of a stock converter that fits, it's just a little looser than stock, and I like it.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
![]() Join Date: Mar 2005
With a 300 horse motor, you really don't need much converter at all. You could get away with a stock converter. If you think about it, Chevy built thousands of 300 horse 327s and 350s, and they all had a stock converter that stalled at about 1600 rpm.
If you want a little more stall, go with an 1800. Let me make a suggestion you. Make sure that when you order the converter, get the one with the lock-up feature. It's like having another gear. Personally, I don't like having any more converter than what the motor needs. If I knew your cam specs, I could tell you exactly what you need.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
I agree completely with chevyrestoguy, you most likely have no need for a high stall convertor. A convertor has more to do with your cam and where you are making your power than how much power you are making. I am running a 2000 rpm stall convertor with lock-up behind a 440ish horse motor, but they key here is my cam makes its power in that range. 406sbc, 700R4, 4.11 gears
stock my wagon had a 14in, had trans built and went with 2200 stall 12in, what a pleasure it is, wish I went 25-2800 10in, I didn't realize how much fun TC flash is
![]() Join Date: Oct 2011
I have a 3500 stall on my truck with a 355 375 hp and 308 gears and I hate it. Stall is way too much in my opinion especially for daily driving.
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
Fabricate till you "puke"
2200-2500, would be way plenty on your app...(especially if you plan on driving on the street)! Little bro , runs a tight 10.... 3200 stall in his S-10 (track only). The old 383 , is around 390-400 hp, runs 3.89 gears & is not fully 'flashed", till the throttle is wide open ! Man does it kick then
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
that can be the trick, not all TC's are built the same, even though there is little inside. a well built one should drive normal until you step on it.
best to avoid catalog off the shelf uni built units..... |
![]() Join Date: Mar 2012
i think the concern here is the overdrive tranny and the 3.08 gears,
back years ago i had a 72 with a 300hp 350 crate 400turbo tranny and 3.08 rear end, it was originaly a 3 on the tree,and when i put the automatic in , i had no take off what so ever, i installed a BM holeshot around 2200 stall and did a curve on the dizzy , man what a difference it made
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Do what I did and make the old lady learn to use 3 pedals. She hated it at first but now you cant pry the keys out of her hand. Her daily driver is a 5spd now that she has racked up nearly 100k miles on. No plans to give up the TDI or the stick shift.
#12 | |
a higher stall TC has to save gas too, I don't go around corners and open all 4 anymore, I just flash it to stall speed n hang on ![]() |
#13 | |
