Old 06-14-2014, 10:04 PM   #1
mike in mo
nv 4500 swap
Ok so I'm swapping a 4500 in my 1980 one ton its in and mounted .working out the clutch details now. I used the 93 bellhousing and am looking for a slave cylinder I know the 93 has the quick disconnect but I seen a slave from a 1990 with a nv3500 that looks right but I don't know . Any ideas other that throw money at it. Thanks up front
mike in mo is offline   Reply With Quote
Old 06-15-2014, 08:35 AM   #2
Wrecked1982
Wrecked1982's Avatar
Re: nv 4500 swap
next week im also starting this swap, I also use the 93 bell housing and will be using the 87 clutch master and hose connected to the 93 hose and slave .im pretty sure it will work, going this route is about haft of the 300 something $ of the right advance adapter direct fit bell housing. mine is 4x4 and will have a 4 inches suspension lift. Some are saying the 93 slave emplacement will interfere with the 4x4 front drive shaft if the suspension is at stock height. I do not know if this is true yet.
Wrecked1982 is offline   Reply With Quote
Old 06-15-2014, 10:07 AM   #3
mike in mo
Re: nv 4500 swap
That is the way I was thinking about doing it till I seen the slave cylinder for the 1990 k2500was looking to see if anyone had used it. And if not why
Old 06-15-2014, 03:12 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: nv 4500 swap
The external slave NV4500 will probably hit the RH drop front driveshaft. That's why I went with the later internal slave tranny. I don't know how much lift it takes to clear it.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-15-2014, 03:28 PM   #5
mike in mo
Re: nv 4500 swap
Mines 2 wheel drive so I don't have to worry about the driveshaft
