06-15-2014, 03:34 AM | #1 |
couple ls swap questions
I am in the process of putting a ls1 in my 67 c10 and it will have a fast ez efi on it.
what pedal are you using and cable? Any suggestions on what length I need? pics would be great. Also are people using the 73- motor mounts or 67 ones? this is the only parts I haven't thought out. Thanks phillip |
06-15-2014, 10:59 AM | #2 |
Truck and auto performance nut
Re: couple ls swap questions
On my '68 I swapped it to the later model ('72 in this case) pedal, bar and cable assembly. Then to get the carb connection right I wound up using a universal Lokar piece for the cable connection. Or by Fast Easy EFI instead of the carb style replacement you mean the wireless/fuel rail/ecm all in one combo that uses a standard efi throttle body?
I tried the ECE mounts that use the later '73 up style mounts but IIRC it left everything too far forward so I wound up using '67-'72 small V8 mounts coupled with standard motor mounts bolted to LS swap plates from TransDapt.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-15-2014, 02:32 PM | #3 |
I used dirty dingo mounts that allowed me to use the stock 71 engine mounts
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-15-2014, 03:12 PM | #4 |
thanks for the info
The fast efi I have setup is like a carb so no fuel rails. |
06-15-2014, 11:42 PM | #5 |
In also used the stock mounts with CPP sliders, for perfect. See build for pics...
06-16-2014, 09:47 AM | #6 |
Phillip - there's a lot of good infor on LS swaps in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=566743
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-16-2014, 11:31 AM | #7 |
I used the Lokar pedal assembly and one of their cables, for my 68. I have an car intake on mine so I cant help with the length.
I am using factory mounts with conversion plates. (non adjustable) |
