![]() Join Date: Oct 2009
Sway bar questions
Finally getting around to installing a sway bar. Anyway, I have a couple quick questions:
1. It seems like 3/8 bolts are a little smaller than the original rivets. Is it best to upsize the hole for 7/16? Or, should I just use 3/8 and not worry about it? 2. I ended up with 1" lowering springs in the front. Would I be better off using factory height brackets or lowering brackets? Or, will it really not make any difference? Thanks!
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Re: Sway bar questions
I just used 3/8" and they pulled the crossmember to the frame just fine, and have not come loose. Mines stock height so can't help you there. Glad your doing it, one of the best things we can do to these old trucks!
![]() Join Date: Oct 2010
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
![]() Join Date: Sep 2007
Your stock brackets will do just fine. Try to use a 1 1/4" or 1 1/8" bar. The original 7/8" bar doesnt seem to do much
1967custom |
