Old 06-15-2014, 11:22 AM   #1
ochre70
Going back to stock height from 2 1/2" drop spindles?
Been thinking about putting the truck back to stock height a lot lately. Just want to get an idea of what I'm looking at. So here's the story... The truck came with drop spindles and springs. I have since put stock height springs in the front and 1 inch taller ECE springs in the back (which look more like 3 inch taller springs to me). I am still not crazy about the ride and I still have issues with rubbing the front inner fenders on big bumps (taller springs + skinnier wheels = better but not perfect). So here's my question: Does anyone know if I can use the CPP rotors and calipers and just swap out the spindles for some factory 71-72 spindles? Will I be better off finding the rotors and calipers also? Here is a before and after of the truck for reference.
1970 Ochre & White C10
ochre70 is offline   Reply With Quote
Old 06-15-2014, 11:27 AM   #2
67ctener
67ctener's Avatar
Re: Going back to stock height from 2 1/2" drop spindles?
As long as its not a brake kit for a modular spindle I would think the stock spindle would accept the cpp disk brakes.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 06-15-2014, 01:13 PM   #3
ochre70
Hmmm. Not sure if its the modular spindle or not. Is there an easy way to check since I don't know which kit the previous owner bought? Also what year trucks can I take the stock spindles from? I know it starts in 71, but whats the last compatible year?
Old 06-15-2014, 01:14 PM   #4
hopped up
hopped up's Avatar
edited: this is not a classified ad thank you..
Last edited by Liz; 06-15-2014 at 10:49 PM. Reason: classified ads belong in the classified section
hopped up is offline   Reply With Quote
Old 06-15-2014, 05:15 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Its most likely not going to be as easy as you hoped. Unless you know exact for sure what the parts you currently have are, you're setting yourself up for trouble.
Heres why...
You're truck being a 70 model uses different ball joints and tie rods than a 71-72 truck does. Its most likely that the spindles you currently have are conversion spindles which use your original spec ball joints and tie rods. Therefore if you swap to a 71-72 spindle, you're gonna have to swap it all. The simplest option would be to buy a pair of stock height disc brake spindles for a 70 model from ECE.
