![]() Join Date: Oct 2010
Cab Rebuilding
Hi all, I am fixing to rebuiled a rusty 72 A/C cab. My question is my rusty cab is my VIN that matches my frame, have another cab that I will be using for patch parts, is there any places on these cabs that have the VIN hidden? Wanted to check and make sure I kept everything for my titled cab in the correct and legal spots.
Thanks Eddie ![]() ![]() |
Re: Cab Rebuilding
There should be a # found on the carb. Dont think it has anything to do with the actual VIN # though. Once you find the carb # check out mikescarburators for quality rebuild kits.
![]() Join Date: Jun 2005
Re: Cab Rebuilding
Um, I think he said CAB not carb....
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: Cab Rebuilding
haha oops
Re: Cab Rebuilding
The only cab VIN number you need to worry about is riveted to the driver's door post. Ideally that should stay with your final cab as well as the factory installed rivets.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
