Old 06-15-2014, 03:37 PM   #1
michael bustamante
michael bustamante's Avatar
brake issues on a 4x4 blazer
okay guys I have an 84 blazer 4x4 all stock. when I hit the brakes normally to a stop, they act and function as normal but when I hit the brakes hard or even kind of hard,my truck pulls to the right like my caliper on the right front is engaging harder than the one on the left. Any ideas as to why this is happening?
1967custom
michael bustamante is offline   Reply With Quote
Old 06-15-2014, 04:27 PM   #2
Cabnchassis
Re: brake issues on a 4x4 blazer
Check the pad wear and see if both sides are worn evenly.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 06-15-2014, 04:36 PM   #3
michael bustamante
Yup i pulled it the other day. And they seemed pretty even. I was thinking the caliper was stickiing but it seems ok
1967custom
Old 06-15-2014, 04:41 PM   #4
geezer#99
geezer#99's Avatar
Tire pressure the same?
Old 06-15-2014, 04:46 PM   #5
Cabnchassis
You might also check your tie rods and all your bushings. My k2500 pulls to one side under heavy braking because my front end is worked over.
Old 06-15-2014, 07:47 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Check the left front brake hose, they pull opposite side when they collapse.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-15-2014, 10:10 PM   #7
michael bustamante
Illl check the tie rods and brake hose now. Thanks guys.. ill let you know what i find
1967custom
Old 06-15-2014, 10:46 PM   #8
SkinnyG
SkinnyG's Avatar
And caster. Uneven caster left-right can cause a pull under braking.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
