99 C1500 Blend Door Actuator STEM SMH :( Toughy
Guys I pulled the blend actuator off the car and much to my surprise the actual stem the blend door fits on is broke. Instead of a U shape I gotta J shape sorta. Upon taking out the ashtray I noticed the actuator was not even connected electrically - raising my eyebrow….I found it broken…. Previous owner
![]() Now how do I fix this? Are these removable without taking out the whole dash? I can not find one single thing on the internet. Is there a genius way to fix it (Mcgyver) I tugged on it with needle noses and it does not seem to come out. I wasn't forceful tho. I need some help Forum. Plastic See pic
Re: 99 C1500 Blend Door Actuator STEM SMH :( Toughy
From the dealership they are telling me that Chevy calls that a "link" They say it's about $44.00 they didn't have a clue on how to tell me to fix it but I need to call back and talk to customer service not parts.
laying low
![]() Join Date: Mar 2001
You may need to hit the salvage yard and have a look at one already opened up and get your parts a whole lot cheaper too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#4 | |
# 21 the left diagram is the one that controls hot and cold behind the glove box ??/
I doesn't move freely....Pretty hard to move by hand cause it's just a stub now. I bought some Q bond and I am hoping I can put the stub back together enough to work.
#6 | |
actuator ( The little servo motor ) Can you take a little pair of vise grip pliers and get on the nub or were you going to wait tell after you apply the Q Bond ??/ Steve
I been waiting till the Q Bond comes in. Kinda nervous to try it without it. Don't want to mess it up further kind of thing.
#8 | |
#9 | |
motor because of the gear reduction ??/ But there shouldn't be any hesitation ( constant ) in the movement and not a lot of pick up ( Slopp ) at the ends of travel ??/ You can even hold a grip on the moving shaft while moving to determine if its weak or faulty ??/
| Bookmarks |
