Old 06-16-2014, 05:58 AM   #1
Charlemagne65
Master Cylinder for '55 two ton
Does anyone know where I can find a dual master cylinder for a 6400? I would like a master that can be installed under floorboard like original.
Charlemagne65 is offline   Reply With Quote
Old 06-16-2014, 10:25 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Master Cylinder for '55 two ton
I think your going to have to get one for a 3500 with a low reservoir. brakes for that size truck move a lot of fluid in and out of the reservoir. Are you using the stock brakes?
Find one in a junk yard and see it it fits under the floor.
dwcsr is offline   Reply With Quote
Old 06-16-2014, 11:03 AM   #3
Charlemagne65
Do you mean like off a modern Chevy 3500? I am running stock brakes. Obviously I want to be very safe!
Old 06-16-2014, 07:28 PM   #4
_Ogre
_Ogre's Avatar
nothing will bolt in and allow you to have under floor dual mc you will need to fabricate a bracket to hold the mc under the floor and the linkage between the pedal and the mc. as suggested by dwcsr, find a newer big truck with drum/drum brakes and make it work
shop air compressor timer
Old 06-17-2014, 11:52 AM   #5
buggy5872
buggy5872's Avatar
The stock brakes system on your 2 ton is safe if it is in good condition. It is most likely a hydra-vac system and converting it over to a modern dual resivor master is not possible without changing the complete brake system.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
