Old 08-03-2003, 06:41 PM   #1
70Chevy4x4Nut
3.08 gears are worrying me
My 70 4x4 has 3.08 gears. What I've read is that they're not worth having. I have a posi in the front and open diff in the back. I am thinking I might just put it all back together as it is and look for some different gears later when I can afford it. How much trouble it is to change out later once everything is back together?
This is one area I feel I need to let someone else do, which will mean big bucks I'm sure.
70Chevy4x4Nut is offline   Reply With Quote
Old 08-03-2003, 07:37 PM   #2
86k10
What exactly is it about them that worries you. I've run them before and thought they were just fine. Just wondering.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 08-03-2003, 08:42 PM   #3
70Chevy4x4Nut
I want to run 33" tires and by what I've read that combo would make the RPM's too low. And by the way I do not have posi in the front like I thought. I spun it at the pinion and they both turned the same way, but I can grab one side and the other keeps turning. This was on a 71 donor axle I want to use for disc brake setup. I guess I got too excited too soon.
I tried to take off a disc rotor on that 71 4x4 dana44. I got to the nut that has a bunch of little holes all the way around. What tool is needed to get in there and break that loose? Need to replace the rotor.
Old 08-03-2003, 09:42 PM   #4
Class of 69
Class of 69's Avatar
You need a spindle nut socket for that axle. May be available at better auto parts stores.. For sure thru Snap-On, Matco, Mac. Been a while since I worked on that specific model, but I thought the rotor fit over the center hub, and studs...didn't need to remove front hub to remove rotor. They get very rusted on, so it may seem as one piece.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-04-2003, 12:59 AM   #5
1969 GMC
1969 GMC's Avatar
someone on this board had a chart about tire size and gear ratio correlation, but i have no idea where it is now. 3.08's probably would be too high to use with 33" tires, IMO. I have 3.73's with 32" OD tires right now, and it seems to be a good medium between performace and fuel efficiency (lol).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-04-2003, 01:36 PM   #6
Prerunner1982
Prerunner1982's Avatar
there use to be one on the 4wheel parts website, but i guess they rearranged as i cant locate it.........
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-04-2003, 01:37 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I have 4:10's with 35's on my '69. My old '72 had 3:73's with 35's and it was a little to high a gearing. The 4:10's are much better. For 33's, I'd think you'd need a minimum of 3:73's. I would also think you'd be able to find them used fairly easily from someone going with higher gear set. Check on CK5.com or Pirate4x4.com for some 3:73's
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-04-2003, 03:07 PM   #8
wildwood
wildwood's Avatar
gear ratio chart
.373s work good with 33s in my opinion. .308s are a little tall for 33s. The chart found here is good but they like their RPM. I'm running .373s with 35s and it works OK with the 4 speed even though it's off the charts here:
http://www.4wheelparts.com/tirel_gear_ratio.asp
I'm assuming you have a 12 bolt rear end. If so you will need a different carrier for .373 and up (numerically). I'm also assuming you have a Dana 44 front in which case you can use the same carrier you have now which is for .373 and down. When changing the carrier you will almost definately need to "set" the gear pattern. A new gear set should come with a helpful instruction sheet. You might want to get this done professionally if your spending $ on a new set. If you buy used and don't mind a slight howl you could set it up yourself. In the front end you may not need to set anything as your reusing the carrier. Make sure to check with gear marker. You should be able to find all these parts no prob new or used. If not I could supply them for you at decent prices (used) but you'll have to pay shipping from Canada. I can get used posi diffs for both.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 08-04-2003, 07:24 PM   #9
70Chevy4x4Nut
Thanks for the input. After much thinking about it, I think I may keep the 3.08's and my 31" tires for now. After I get it on the road, I will have a feel for this combo. If I like it then great. If I want to change, then I will rebuild the other front and rear axles that I have and just make a complete swapout. That way the truck does not sit for too long. I will do a lift and bigger tires all at the same time. Less money now and on the road quicker. Some may not like that idea, but I can see lots of more spending on the way.
Old 08-05-2003, 11:36 PM   #10
MJN
MJN's Avatar
I've got 3:08 posi in my '72 Blazer with 35's and it sucks. Great mileage on the open highway but it really drinks the gas going up hills and through town and in the mud you can't get enough power to the ground. I would love to upgrade to 4:10s.
Old 08-07-2003, 07:36 PM   #11
blazerboy72
I have 3.73 with 38's so you should be fine with 3.08 and 33's
blazerboy72 is offline   Reply With Quote
