06-16-2014, 11:57 AM | #1 |
67 327 stock timing chain/cover question
I have a 1967 327 275 hp car engine with a single chain from factory. It was original I think cause it had the nylon on the cam gear still. I am rebuilding the engine and I have a buddy who has a gm double roller in the gm box. He said I could have it for a very reasonable price but my concern is will it fit under my stock timing chain cover without rubbing of causing me grief. I don't want to change anything so if it doesn't fit I wont bother with it. anyone have info on this. Thanks, Rod.
06-16-2014, 12:57 PM | #2 |
Re: 67 327 stock timing chain/cover question
For a stock application I would go with option "C" which is a good quality single roller steel chain. The double roller will probably fit OK, but is not necessary for a stocker-see how long the original lasted with a nylon gear.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-16-2014, 01:04 PM | #3 |
I hear ya. wouldn't even question it but the the double chain is damn nears free. I assume that they put the nylon on to quiet the chain down? Is the nylon really needed?
06-16-2014, 02:37 PM | #4 |
You can get a stock (steel) timing set from AutoZone for $16. That is not very expensive. Yes, the nylon is to quiet it down. If you can get the double roller cheap, it is OK too.
06-17-2014, 04:44 AM | #5 |
Back a few years, put a double roller on a 69 350 s/b and didn't have any issues using the stock cover.
