Intake help
Single or dual plane on 454 whats better ?
Soon to have 68 SWB 350 with Turbo350 |
Formerly yellow72custom
Dual plane for a high-performance or stock street motor, single plane for a street/strip or racing engine.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Fabricate till you "puke"
on a 450+ cube street eng, I dont think the single plane intake will hurt the bottom end.....maybe rough on milage tho. I ran a Torker on a 455 olds( in my pickup), & it worked pretty well.....if there was any low end power lost, i sure didnt miss it!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
So a dual plane is good for take off power ?
The dual plane intakes tend to give better low end tork, which is what you need for a heavy hauler. sb powered trucks should have a dual plane for sure, but if the BB is a "toy"(not driven daily) I would look at the single plane intake. Its real hard to "kill" the low end tork in a large cube engine. My BB Olds ran a mild Engle cam (shaved heads, headers, torker & 800 dp). The elect kick down Had to be unhooked, cause the truck would do nothing but roast tiers & get squirrley when it shifted fron 3 to 1 @ 35 mph.....it was rough on gas too! crazyL
