Old 06-16-2014, 03:01 PM   #1
JointTech
JointTech's Avatar
remove parking brake pedal assembly
Im trying to remove my parking brake pedal assembly. Its unbolted from the firewall and inside the cab but I dont see how it comes out. I cant turn it sideways because the studs are still sticking out the cab. and it wont go forward because the dash is in the way.
any idea?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-16-2014, 03:07 PM   #2
JointTech
JointTech's Avatar
Re: remove parking brake pedal assembly
72 C20 Long Bed
Old 06-16-2014, 03:19 PM   #3
JointTech
JointTech's Avatar
Looks like the ebrake release handle needs to be removed so I can move the assembly up and then forward.
Looks like the handle is riveted to the assembly. grind it off or something easier??
72 C20 Long Bed
Old 06-16-2014, 03:36 PM   #4
Lee H
Lee H's Avatar
Slide the dash end toward the right.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-16-2014, 04:05 PM   #5
JointTech
JointTech's Avatar
ill try that when I head back to the office but I thought I pushed pretty hard on it and the studs keep it from going sideways very far.
thanks
72 C20 Long Bed
Old 06-16-2014, 05:09 PM   #6
davepl
davepl's Avatar
Slide right, drop below dash line, slide back left and pull it out. I don't think the ebrake handle has any influence, but if yours is riveted sideways you might as well fix that anyway, because I'm pretty sure that's not stock.
Remember you don't have to push it far, just far enough to "unhook" the front from the dash. You're not trying to -remove- it out to the right.
Check with something before grinding it off....
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-16-2014, 05:42 PM   #7
Lattimer
Lattimer's Avatar
What they said. I replaced mine a couple months ago. Pull the front edge to the right until you can just pull it down from the dash, then straighten back out and rotate down and off the studs. It fits tight and took some muscle.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 06-16-2014, 05:45 PM   #8
JointTech
JointTech's Avatar
uh oh. I have to use man muscle? could be a problem.
72 C20 Long Bed
Old 06-16-2014, 06:06 PM   #9
Lattimer
Lattimer's Avatar
It wasn't too bad, I only cussed 4 or 5 times.
Shawn
Old 06-17-2014, 02:50 AM   #10
JointTech
JointTech's Avatar
doh. it didnt even take man muscle. slight tap to the right and it came out. I must have been feeling pretty wimpy on the first try.
thanks
72 C20 Long Bed
Old 06-18-2014, 08:22 AM   #11
snipescastle2
snipescastle2's Avatar
Talking Re: remove parking brake pedal assembly
Hi! There are three 9/16" bolts on the far left of the dash (behind it) I you take these out, you should have enough flex to pull it out.
HTH,
Ben
snipescastle2 is offline   Reply With Quote
Old 04-23-2015, 12:20 AM   #12
zosoppp
Finally got mine out of the 1970 tonight as well. One tip, the pedal assembly comes out easier if the pedal is in the UP (brake off) position. Of course the cable should already be removed from the assembly (one cotter pin holding in the clevis pin attaching the cable end to the pedal lever, and remove the nut and bolt holding the cable housing to the forward end of the bracket.
zosoppp is offline   Reply With Quote
