Old 06-16-2014, 03:10 PM   #1
chevyCO'71
chevyCO'71's Avatar
'71 K20 Destroyed Bearing
Hello everyone, My bearing on my 1971 K20 front right seized and almost yanked me off the road the other day. The inside of the hub where the bearing chase sits got some gouges, and the locking hub took some damage also. Upon dismantling it I had to cut the locking nuts off because they were warped into ovals. It looks like the spindle threads are still ok though. I haven't done this before, I found the Chiltons and Haynes manuals cheap so I picked them up.Can i find a single locking hub to replace the damaged one or are they hard to find as a single? Do I need to replace the hub since it is gouged (see pic)? What brand bearings are suggested? The last shot is how it sits now. I'm assuming what is still on there is what is left of the old bearing. Thank you any advice/help you can supply!
chevyCO'71 is offline   Reply With Quote
Old 06-16-2014, 03:16 PM   #2
casper71
Re: '71 K20 Destroyed Bearing
go to a salvage yard, you should be able to get the hub and spindle with locking nut. this would be the cheapest way to go
casper71 is offline   Reply With Quote
Old 06-16-2014, 03:21 PM   #3
BLT gmc
I think you can clean up and re-build what you have. The inner races of both bearings are still on the spindle. They should be easy to cut off. The outer race on the inside bearing still appears tight to the housing. This is also a good sign. Best way to remove them is to weld a bead right in the middle of the race all the way around where the bearings would run. As this cools it will contract and make the race smaller, it will then all but fall out. Obviously you will need new locking nuts and a good clean up. Remeber the driver's side may not be far behind this one. Good Luck, Bruce
BLT gmc is offline   Reply With Quote
Old 06-16-2014, 04:07 PM   #4
SS Tim
SS Tim's Avatar
Originally Posted by chevyCO'71 View Post
... I found the Chiltons and Haynes manuals cheap so I picked them up...
RTFM ... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 06-16-2014, 06:18 PM   #5
chevyCO'71
chevyCO'71's Avatar
Alright, so I'll call or hit some salvage yards after removing the rest of the bearings. I took the left side apart to help me figure out what I was looking at on the right. It is back together now but I'll probably take care of those too.
Bruce, so not all bad news, nice. I have a welder so I could try that trick to get the race off.
SS tim...I'll read that factory manual, thanks
Old 06-16-2014, 06:36 PM   #6
gvw5400
gvw5400's Avatar
Bummer about your wheel bearings signing off.
Welding on the race works well, you can also grind a couple of grooves across the race with a thin cut off wheel, wrap a rag around it and use a cold chisel and bfh (hammer)
to break/ separate the race. Don't grind too deep and get into the spindle.
Timken bearings and National seals have been good to me over the years.
All the best, Dirk
gvw5400 is offline   Reply With Quote
Old 06-16-2014, 07:56 PM   #7
imjeff
imjeff's Avatar
I'm guessing those "inner races" that used to be part of your wheel bearings have ruined your spindle. Since they normally slide on and off with a hammer or a press the surface underneath is probably toast. I wouldn't trust them anyway. You don't know how hot that spindle got or how much stress it took when it yanked you off the road. Good luck.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 06-16-2014, 08:35 PM   #8
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I would replace the spindle also unless its not grooved or discolored from heat.
As for bearings, anything US, Japanese, or German made is what I prefer.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 06-18-2014, 09:21 AM   #9
BLT gmc
I agree with the above. If there is any evidence the races have spun or got hot, replace the above mentioned parts. It is difficult to judge by picture only, but I do not see obvious signs of spinning or excessive heat in the picture. Good luck to you, Bruce
Old 06-20-2014, 09:37 PM   #10
chevyCO'71
chevyCO'71's Avatar
Thanks for the advice on the damage and which brand bearings/seals. It sounds like I will know more once I try to pull the rest apart and see under the races etc. Hammer and grinder...Hopefully the spindle is good, if not I'll replace it and do the bearings on the other side too.
thanks again, nice rides guys
