06-16-2014, 07:41 PM | #1 |
700r4 detent cable on a rockchester one barrel
I am about to hook up my 700r4 to my 250 straight 6 , the cable is the only thing that's been hard . Before I explain my idea I was wondering if anyone else has succeeded in hooking the cable to a stock one barrel carb ?Mine is a hard thing to do because the movement is backwards on this carb compared to other applications , so anybody done this ?Oh and please don't make fun of the 6 its the original and has 25000 miles on it ,I thought if I could get her up to 70 and only wrap 2000 rpms it would be cool for a while till I decide if I want more motor or not. Its got a 3;73 posi and its a 2wd c10 1968 long bed step side.
Last edited by magicmikeinc; 06-16-2014 at 07:50 PM. Reason: adding another thought |
06-16-2014, 11:15 PM | #2 |
Re: 700r4 detent cable on a rockchester one barrel
I've got a 200 4r in mine with a 250 inline 6. I never found a good way to hook my TV cable up, so mine is rigged....It works, but it is not pretty. I love it though. I also have 3.73 rear, and at 70mph, I can hardly hear it running. I don't have my lockup connected either, which some of the experts say this is wrong, but I've driven mine hard for 2 years, and never had a problem. Here are some pics. I welded a tab to my accelerator arm and put the round brass cable stop on the cable, and the welded tab pulls against the brass piece. I also fabbed a bracket up to hold the TV cable, and bolted it to the manifold.
Mark _____________________________________________ 1968 c10 stepside 1948 GMC 1969 Chevelle |
06-17-2014, 08:36 AM | #3 |
Here is how I did mine on my 64 chevelle it has a drive by wire ls engine , so I hooked it to the pedal with a roller up top , works great ,,, mag c10s looks to be a clean an efficient way also
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-06-2014, 08:28 PM | #4 | |
08-06-2014, 08:30 PM | #5 |
Too cool and hidden , that's nice
08-06-2014, 09:10 PM | #6 |
Oh no I just looked at the starter again and the flywheels so big I think it'll have to be changed to a smaller diameter one . Its a 14'' and its like so close to the bell on the tranny I don't think any starter will fit ,**** !
08-06-2014, 10:32 PM | #7 |
This is the way I'm headed:
http://67-72chevytrucks.com/vboard/s...d.php?t=638139 I need to build a new bracket, but after seeing where I was and with some good help, I think my next try is going to work. Now, I turned my carbs 180, so the linkage is on the outside, so I'll have to fab some more stuff once I get my body back on, but that don't seem like too much trouble.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
08-06-2014, 11:35 PM | #8 |
All i can say is one its not a detent cable but a tv cable that controls the line pressures from the pump if it is not setup right the trans will burn out in less the a mile.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Tags |
700r4 swap straight 6 |
