Old 06-16-2014, 10:06 PM   #1
jondancer
Gear selector does not lock in place ...
My 72 c10 350/350turbo gear selector moves freely from gear gear . I'm used to newer vehicle where you have to push the brake to select a gear. Is something broke or is this how a 72 works?
jondancer is offline   Reply With Quote
Old 06-16-2014, 10:16 PM   #2
spatz
Re: Gear selector does not lock in place ...
this is how all vehicles where back then. its not broke.
spatz is offline   Reply With Quote
Old 06-16-2014, 10:18 PM   #3
jondancer
Well is there a way to change it?
Old 06-17-2014, 07:26 AM   #4
Keith Seymore
Keith Seymore's Avatar
I'm not sure I understand the question.
New vehicles have a "park interlock" system so that you have to push the brake to move the shift lever from Park (vintage vehicles do not have this). That's the only gear that is captured in that way. We press the brake while shifting from reverse to drive or whatever just to keep the vehicle from moving while doing so, but you don't have to press the brake.
Now, if you are saying there is no "feel", or detent, between any of the gears: that is the result of the park pawl/gear selector inside the trans. It looks like a "rooster comb" with a bunch of notches in it. There is a roller that nests in the various notches to give you the "feel" that you have selected a particular gear. This is true even for vintage vehicles.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 06-17-2014, 07:34 AM   #5
jondancer
Thanks, I was hoping for a park interlock
Old 06-17-2014, 08:29 AM   #6
Keith Seymore
Ok; thanks for the clarification.
I believe my '74 Chevelle had a park interlock (it was removed long ago for header clearance). Trucks normally followed passenger cars by a bit so I suspect it would be a couple years after that before it was introduced to the C/K lineup.
K
1979-1986
1986 - 2019
Old 04-19-2015, 02:00 PM   #7
jondancer
Back again! So when the vehicle is in park , the gear selector should be able to be moved into drive without applying brake or pulling back on gear sector?
Thanks guys
Old 04-19-2015, 02:21 PM   #8
Keith Seymore
Yes- you should be able to move from park without hitting the brake.
No - you will still need to pull the handle towards you.
K
1979-1986
1986 - 2019
Old 04-19-2015, 05:09 PM   #9
jondancer
Dang mine pulls down without any resistance from park. Like it's not locked into park. It goes from Park to reverse very easy, then I can feel all the other gears. What could be broken?
Old 04-19-2015, 05:12 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
Can you feel any tension pulling the shifter towards you? It should move back and forth and that should lock it in park. You could try spraying some lube in the shifter handle and see if that loosens anything up.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-19-2015, 10:44 PM   #11
leftybass209
leftybass209's Avatar
Shifting through the gears without pulling the lever back means the mechanism is binding, or cruddy with old grease. In that instance a spray lubricant might work at the cost of making a huge mess. The best thing to do is rebuild the column, as the bearings probably need to be replaced anyways. Or, you can always convert to a tilt.
leftybass209 is offline   Reply With Quote
Old 04-20-2015, 06:55 AM   #12
jondancer
Mine is tilt
Old 04-20-2015, 12:31 PM   #13
leftybass209
Sounds like a rebuild is in order. Mine is rebuilt and it's smooth as silk, with a very positive forward pull motion out of park.
