Old 06-17-2014, 08:54 AM   #1
smoked68
smoked68's Avatar
No Brake lights or turn sigs
Hi guys, we installed the led tail light assemblies with the led flasher. Now I have nothing?? the running lights come on, just no brake or turn sigs. I am at a loss, Help. I thank you in advance, Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 06-17-2014, 08:56 AM   #2
smoked68
smoked68's Avatar
Re: No Brake lights or turn sigs
And yes everything is plugged up correctly. Gotta be these leds??
Old 06-17-2014, 09:27 AM   #3
sboris
sboris's Avatar
Make sure and triple check all your grounds. Could try plugging the old ones back in to see what you've got to isolate it.
Double check the LEDs are for a twelve volt system. Had that happen once. Throws everything off.. Just some thoughts
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 06-17-2014, 11:43 AM   #4
smoked68
smoked68's Avatar
Bought all from LMC, lights and the flasher. Supposed to be for the 68?? I do not have the instuctions on the flasher anymore the body guy tossed. How does it wire up, I know it would not plug into the factory flasher place??
Old 06-17-2014, 12:39 PM   #5
RManson
You might have to ground the taillight housing directly to the body, but I'm not sure how the LED setup is designed. I know I've had a similar issue with the stock assemblies on a new bedside. Attach a ground wire to the housing and one to a good body ground and see where you're at. Good luck and post some pics when you're done!
RManson is offline   Reply With Quote
Old 06-17-2014, 02:29 PM   #6
smoked68
smoked68's Avatar
Will do and thanks
