Axle tube seal??
Is there a seal that should go between the outer axle and axle tube? This is in the front on a 70 k5. Just seems like there should be something to keep water and dirt out. There was nothing there on disassembly.
![]() Join Date: May 2007
Re: Axle tube seal??
The only axle seals are the ones right next to the center section.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Thanks.
I did see a aftermarket seal for there. Dont know if it works or not. It would be a tough place to seal because the shaft moves around when turning left and right. Not to mention if water did get in there, it would stay in there until you removed the seal to let it out.
I made a scraper on a piece of pipe to clean out the axle tube whenever i pull my axle out. It dosent make it squeaky clean but it gets the big chunks out.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Currently Blazerless
I agree with OLDCHEV4X4 I made a scraper from a large washer and 1/2" steel rod, whenever I have an axle out the tube gets a good cleaning. You would be surprised at the sludge and scale you can get out of the axle tube. If you don't do this that stuff gets dozed right into the middle of your ring & pinion case.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
