Old 06-17-2014, 11:17 AM   #1
dman1982
dman1982's Avatar
water pump....wierd...wtf???
so i went to the veterans affairs office this mooring, when i got there i looked under my truck and it was leaking coolant, so i pop the hood of course, and it was leaking coolant from the bearing in the water pump, so i took a chance and drove it home and it wasn't leaking...is this a common issue?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 06-17-2014, 11:19 AM   #2
littlevictories
Re: water pump....wierd...wtf???
yeah that's where they die. when the truck goes from a hot,run to a hot, off the pressure in the tank builds (no airflow through the rad) and then it leaks. bummer in the summer.
littlevictories is offline   Reply With Quote
Old 06-17-2014, 11:22 AM   #3
dman1982
dman1982's Avatar
so i need a new water pump? it does need a new thermostat, its stuck open so it hasn't been running hot, i should have plenty of air coming through the rad, it did it after highway driving
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-17-2014, 11:25 AM   #4
littlevictories
yes, the shaft seal has failed. a new pump is in order.
new thermostat yup, they're cheap.
you running a purge tank? highly recommend one on any vehicle. proper psi cap is another key.
Old 06-17-2014, 11:31 AM   #5
dman1982
dman1982's Avatar
got the purge tank, guess ill see about going to get a new one, and get the psi cap...whats the proper psi?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-17-2014, 11:38 AM   #6
littlevictories
15 psi is stock, and what I used. They do go bad, but usually they pop at a lower pressure rather than a higher one. Cheap enough to just do it.
Old 06-17-2014, 11:42 AM   #7
dman1982
dman1982's Avatar
gotcha...gonna go out here soon and try and get a water pump...anything special about changing one of these water pumps?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-17-2014, 11:51 AM   #8
littlevictories
nah, not really. the gaskets are like the other gaskets on the motor steel core with a neoprene sealing edge. $5 each and you will need two.
Old 06-17-2014, 11:54 AM   #9
dman1982
dman1982's Avatar
gotcha....didnt know if you had to shim it or something weird like that
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-17-2014, 12:43 PM   #10
truckdude239
truckdude239's Avatar
nope watch out the last couple of pumps i have bought at work came with the cardbopard gaskets, by the metal with rubber inserts, make sure to buy the same pump and stat brand as there are different size t-stats, i did install one with the card board gaskets and rtv been 12k miles so far no issuse but i like the factory gaskets
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-17-2014, 12:44 PM   #11
dman1982
dman1982's Avatar
Thanks for the heads up
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-17-2014, 01:42 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
nbuy the same pump and stat brand as there are different size t-stats
This intrigues me. It would be super weird for companies to put a proprietary stat in a stock replacement water pump, unless they were trying to "Fix" something seen as a weak point from O.E.
That would also mean that 3rd party stats (like the 160*s) wouldn't fit any pump other than the original one.
Did you have this problem? I'm curious what didn't fit, and by how much.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-17-2014, 05:47 PM   #13
solidaxel
solidaxel's Avatar
Tell me about who has the best pumps cheap!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-17-2014, 08:38 PM   #14
truckdude239
i bought an ac delo pump fro aut supply here and the had 2 different size thermostat housings
David fuller
2000 Tahoe 5.3l 378
Old 06-20-2014, 07:03 PM   #15
dman1982
dman1982's Avatar
so i started my truck and drove it around a bit, now its now leaking....wtf???? so freaking weird!!!! it makes sense about the rad tho I'm pretty sure that its not holding pressure so that would explain the low pressure leak...but still makes me mad tho
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-22-2014, 01:55 PM   #16
dman1982
dman1982's Avatar
so, my water pump isn't leaking anymore, should i still get a new water pump, radiator, and thermostat? getting ready to fix this, can i re-use the metal gasket on the water pump instead of the cheap ones you get from the new water pump?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-22-2014, 01:55 PM   #17
dman1982
dman1982's Avatar
or should i try my luck with just a new thermostat?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-22-2014, 03:59 PM   #18
truckdude239
If it was leaking replace it. Do not reuse the gaskets
David fuller
2000 Tahoe 5.3l 378
Old 06-29-2014, 02:20 PM   #19
dman1982
dman1982's Avatar
well i replaced it almost a week ago...kinda slacking on the updates...new water pump, rad, and bought the better gaskets for the water pump, had a buddy at orileys buy them for me saved me about 50 bucks, came out to 212 so not too bad
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-29-2014, 02:21 PM   #20
dman1982
dman1982's Avatar
oh and with the rad instead of the 1 inch went with the 2 1/4 inch one...and i put my electric fans on
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
