What is missing on this Rochester B
Chipping away at items on my "get the truck restarted after 13 years" list...
The carter W carb that was on it is totally filled with nasty varnished gas- so decided I will rebuild the rochester b that came in a parts bucket with the truck. I pulled it out and was looking at it last night- and realize that its missing something. I think there should be some sort of linkage, or kick-off or something screwed to that pivot on the front- goes between the choke & the throttle arm. ![]() Can anyone with one of these carbs take a close up pic so i can see what it looks like? Does it have a spring under it, or any other peices I'm missing? Thnx
_____________________________________ Ben R. 1953 Chevy 3100 Classic Seat Restorations -Preventing me from working on my own projects since 2009! |
Re: What is missing on this Rochester B
http://67-72chevytrucks.com/vboard/s...d.php?t=481531 |
Your missing the main arm, and the little round return spring that goes around the mounting screw.
GMCDAC
Hi Rambow, Hogger54's advice is right on. I have 2 model B's and they are a little different from each other and also from yours. It appears that the missing parts on yours are probably the same as all of these pictured carbs.
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
