Old 08-03-2003, 08:25 PM   #1
nejeff
NOW WHAT??? carb problems are killing me
I just swapped in a 307 2-barrel into a auto truck (72) and now all I have are hassles. Barely started ( had to hold foot to the floor) and then realized it was missing two carb bolts. Replaced them and now can't do anything but backfire or flood this pig! I think I hooked all the linkage back up correctly (the 307 was a Manual) but I never had starting trouble when it was in the manual truck but it did hesitate a lot when you stomped on it.
I can't adjust carbs well at all and can't figure this s@it out!
Help if you can
72' Chevy Super Cheyenne LWB
72' Chevy C-10 (307 Parts Truck)
nejeff is offline   Reply With Quote
Old 08-03-2003, 08:26 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Could be the accelerator pump gone bad.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-03-2003, 09:56 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Basic carburetor adjustment: There are two idle air screws on the base of the carb, at the front. Turn them in until the just barely seat (stop turning). Then, back them out 2 full turns. This is the basic adjustment, and assumes that the rest of the carb is working properly.
Fine tuning the carb may require a vacuum gauge, a tachometer, or both, since you will be making that same idle are adjustment but tweaking them to get the highest vacuum and a smooth idle, probably about 700 RPM's in Neutral, or about 650RPM's, in Drive at idle.
These are just ball-park figures. If you truly are not comfortable making the adjustments, by all means let someone do who is capbable. OH, make sure the ignition system is up to snuff. Carbs get the blame for ignition problems, and ignition systems get blamed for carb problems. If you don't know which one is the problem, get someone who is capable, to help.
Member Nr. 2770
Old 08-03-2003, 10:26 PM   #4
71elect
nejeff,
Man I know what you are going thru now! I have a 71 GMC w/ 307, 2 barrel carb & manual 3 speed. It started with the simple, hey I'm gonna change the plugs and wires. Got the plugs & wires changed but for some fluke when I started up the truck the needle got stuck in the carb and now it flooded all the time. Rebuilt the carb and set it up to the rebuild specks, including turning the idle screws both back out 2 full turns. But all I got was a crappy backfiring idle that sometimes stalled. Well I set the timing, set the dwell, adjusted the idle, replaced the points,the condenser, the cap, the rotor, heck I even thru in a hi performance coil out of the camaro. But still no luck. Finially I tinkered with the idle screws one at a time by slowly backing them out further than the recommended 2 full turns. Man I was happy that now it was running smooth and had no hesitation at instant throttle. Kind of an expensive lessen to learn though. Hope this helps in the fact that man I hear you. PS watch out for fouled plugs also.
Josh
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 08-04-2003, 12:15 AM   #5
nejeff
Thanks guys. I'll try all that stuff tomorrow. Did not know if I screwed up the linkage or something
Thanks again
