06-17-2014, 10:01 PM | #1 |
hole in crossmember
While I was taking my 1950 3100 apart, I found this hole in the front crossmember and thought, hey, that's strange, maybe the PO cut it out when changing the radiator? But then I saw in a build thread or 3 that others have the same kind of holes. Can anyone clue me in on what causes these and how you've fixed them? Enough to weld up filler or should I replace the member?
06-17-2014, 11:33 PM | #2 |
Re: hole in crossmember
I've worked on three of these and never saw anything like that. If the remainder of the crossmember is good, I would weld in a piece...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-18-2014, 01:18 AM | #3 | |
Hollister Road Co.
06-18-2014, 02:05 PM | #4 |
Thanksfor setting me straight. I figured "billy" (my nickname for the PO, as in "hill") must have cut the member to get a radiator out when a bolt froze.
Compared to my 71, this project has had more than its share of surprises...the longer these trucks live, the more people f&$k with them... |
06-18-2014, 02:22 PM | #5 |
I'd say Dave hit it right on the money. Looking at the other side it looks like the bolt holes over there are wallowed out from things moving around.
06-18-2014, 03:22 PM | #6 |
Moderator
The frame that came with my '50 had that plus alot of heavy pitting. I pitched it in favor of one in much better condition, but that was just across town for $50. Speedway does sell all the crossmembers now, that's an option!
http://www.speedwaymotors.com/Radiat...kup,63704.html
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
06-18-2014, 03:28 PM | #7 |
Leevon, that radiator mount looks interesting, thanks, but on my truck there is a single crossmember that also acts as a front engine mount for the I6. If I was going V8 I probably could (would have to?) use that part, but I'm staying with the stovebolt.
My frame is otherwise in great shape, save for one cracked running board mount, which I can probably also fix with a bit of welding, so I'm gonna stick with it. |
