Moderator
![]() Join Date: Dec 2012
How many floor to frame bolts, long fleet?
How many bolts are supposed to hold my bed on? Six in front of the tubs, six in back?
Re: How many floor to frame bolts, long fleet?
I believe there are 10 bolts on the long beds and 8 on the short beds.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Moderator
So why are there 12 spots to bolt the bed on? Damn. I need two more bolts and washers. I already drilled the bed...
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
8 bed to frame on short fleet and 10 on long fleet
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Moderator
So which two spots DON'T get bolts? There are definitely 12 spots.
Can you provide a picture of what you have?
Two rear cross member mounts
Two in cross member front of rear Three cross members in front, between the cab and wheels. I can get a picture when I get home. I have a long bed frame i believe.
Moderator
![]() Not a great pic. The two bolts closest to the gate go through those V mounts that are on the rear bed support. The next two rows go through the two crossmembers. Ignore the two extra bolts without washers, someone else got drill happy on one side, so I drilled a matching "wrong" hole on the other side to drop a matching bolt into. Hard to see up at the front, but the holes are in the correct spots up there. Two narrow, one wide each side. |
See if this helps any...
And just for FYI...the short stepsides have 6 bolts. This is from 2012 when I replaced the floor
Moderator
lol, three in the back, two in the front. I guess the answer is... you can put three in the front and three in the back (but some people don't). You can also put them narrow or wide on the two back ones closest to the tubs. The other ones have to go narrow, except for the ones at the front closest to the tubs, wide only.
ahhhhh
63 big window lwb bagged and shaved |
#13 |
So, looking through this... Do the bed bolts always go through the wood to the frame? or has anyone done them hidden underneath the boards for a cleaner look?
#14 |
yes i did
#15 |
#16 |
On my '60 GMC I have 6 per side, see picture
http://s1299.photobucket.com/user/jb...23904108567829 |
