choice of bags
I'm looking to start piecing things together for bagging my 78 long bed.
What bags do y'all like. Use. Recommend.... truck is a sbc now but plan on a Bbc later And any other info. I'm bee to this side of the world getting some research in
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers 1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles "Life is full of decisions, we make them and dont look back" |
Re: choice of bags
There are a lot of different bag choices out there. On here, you will see a lot of guys either use Slams or AirLifts. I usually will use the AirLifts, since they are priced well and a good product. The Slams won't "balloon" under inflation, but I don't necessarily think the AirLifts do that much. In our trucks, it isn't too much of a concern.... but all depends on how your suspension is setup, but usually have plenty of room.
Some have more lift than others, but again, for most applications, the AirLift does well. |
Re: choice of bags
Cool a guy offered me a set of re6s for 60 bucks. I just bought fiddlers off him so hes offering those. Would I benefit from them? I know ill be asking dumb questions but just tryingto get my feet on the ground with the air suspension world
Re: choice of bags
RE6's are small for your truck as they would run stiff very stiff.
I like slams because they off 3 different versions of bags, and I helped tune a air bag truck with them. |
Re: choice of bags
If they are used bags i would pass on them.On bags you want to run the biggest ones you can so you have a smoother ride.A bigger bag will take less psi to lift the same weight and height then a smaller bag.And with a air bag the higher the psi the stiffer the spring rate becomes so stiffer ride.
Re: choice of bags
gotcha..... like I said gentlemen I am a newb to all this so im not even sure what bags are what and the highest I can go or the lowest I can go. I am trying to do all kinds of research and make sure all is in line before I start purchasing things
Re: choice of bags
I've been using Firestone 2600 bags at all four corners with no problems. Carried engines, C10 beds and motorcycles with no problems. Truck is a stepside with 6.0 LS and 6 speed manual. Iron block (lQ4)
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
