Old 06-18-2014, 05:33 PM   #1
Ricos54
Ricos54's Avatar
Running wires from your doors?
If your running any type of wires from your doors into the cab how are you doing it so the wires don't get pinch? Our doors shut and open a lot different than other trucks and I want to find a safe way to run my electric windows and speaker wires from the doors into the cab. Pictures would be great or a company you bought the wire conduit from.
Ricos54 is offline   Reply With Quote
Old 06-18-2014, 10:20 PM   #2
youngrodder
youngrodder's Avatar
Re: Running wires from your doors?
I used the ones simular to the "Magnum shooters" on the link provided (Bottom of page).
You can get them in any combination to run power window, door silonoids as we as for a dome light.
http://zigsstreetrods.com/Pages/dooracc.html
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-19-2014, 01:37 PM   #3
OrrieG
OrrieG's Avatar
use the box above and search the site, this topic has been discussed at least twice in the last year, recently about 2 months ago. they have pics, etc.
OrrieG is offline   Reply With Quote
Old 06-19-2014, 01:42 PM   #4
BADAZ chevy guy
BADAZ chevy guy's Avatar
I found a set of full power doors at the wrecking yard and got the OEM rubber boots out of them. (Door to jamb boot)
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 06-19-2014, 09:18 PM   #5
skip99
skip99's Avatar
Saw a neat...yes i said neat.......little trick, a guy just bent brake tube to follow the hinge and tacked it on....
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 06-20-2014, 09:11 PM   #6
sqrlnts
I am a cheap bastard, I ran my speaker wires along the door hinge on my '57.
sqrlnts is offline   Reply With Quote
Old 06-21-2014, 10:49 PM   #7
solidaxel
solidaxel's Avatar
I did the same but I covered them in 2 layers of heat shrink and tied them to the bottom hinge
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
