is my rear end ruined? Pics!!
Just noticed this hole behind the race. Now what? Shaking head....
Re: is my rear end ruined? Pics!!
Feed/drain for fluid to the bearing. Fuggedaboutit.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
I'm just glad to be here!
I think that is oil drain back to the case. If you think there is a piece in there you should be able to pull the cover and find it.
Too hard to tell in the pic if that is just casting flash or a broken edge...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I just came across a 2005 2500 Silverado rear with 25000 miles on it. Its a 8 lug and a 373. Would that work as a replacement if needed?
I'm saying it's meant to be.
I cannot for the life of me imagine how that could have been broken, in use, without splitting the housing into pieces. It's a passage that feeds or drains fluid to or from the bearing. Check figures 22 and 23: http://www.pirate4x4.com/tech/billavista/Gear_Setup/
#7 | |
The bearing that slides over the threads on the pinion, do I need to pack it with grease or does it just run off rear end fluid?
Just a quick assembly grease. Run it for a bit and change the fluid
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
gear oil. no grease
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
There's way more going on than just sliding the pinion bearing back in place. You need to address the crush sleeve and bearing preload. I'm the very last guy on here to spout out ominous warnings, but that's one bearing you've got to get right when you're changing it.
