Old 06-19-2014, 10:35 AM   #1
bigunde
Rusty Rockerfeller
8.1 miss
2001 GMC 2500HD seems to want to miss when you first start it up. you can feel almost a dead miss but seems to clear up after reving it up a few times. Installed new fuel pump and new wires with plugs? Could this be an injector? It does it everytime you shut it off for a while.
bigunde is offline   Reply With Quote
Old 06-22-2014, 07:06 PM   #2
clinebarger
Re: 8.1 miss
Check the Fuel Pressure Regulator for leakage, If fuel is present in the vacuum line, Replace regulator.
clinebarger is offline   Reply With Quote
Old 06-22-2014, 09:20 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
Re: 8.1 miss
It could also be an injector that is partially stuck open. Both fpr and leaking injectors are very common on the 7.4. I'm not sure if the 8.1 had injector issues or not.
95 S_Trucker is offline   Reply With Quote
