Old 06-19-2014, 11:11 AM   #1
1moretoy
porter built A arms
Those with tubular arms what are you using for the lower shock mount? The only studs I can find have 1/2 threads where the stud mounts and the hole on the arm is drilled for a 7/16 bolt. If I drilled the hole out I'm afraid it wont leave much material left.
1moretoy is offline   Reply With Quote
Old 06-19-2014, 11:37 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: porter built A arms
Something like this or call Porterbuilt,... they should have them.
I would drill the hole to 1/2".
http://www.speedwaymotors.com/Shock-...tuds,5485.html
Shock mounting stud is approximately 3-5/8" in overall length.
The part where the shock rides, is 5/8" O.D. and approximately 1-1/4" wide and the threads at the shock end are 7/16"-20, about 7/8" long.
The threads at the bracket end are 1/2"-20, about 1-1/8" long.
Keith
Convert to disc brakes.
Old 06-19-2014, 02:32 PM   #3
1moretoy
Thank you lolife. Since I'm running 1" narrowed arms should I use shorter tie rod sleeves? I like the Edelbrock 5251 hex style.
Old 06-19-2014, 02:39 PM   #4
lolife99
lolife99's Avatar
I think I would just cut the outer tie rod down 1".
What year spindles and tie rods are you using?
Keith
Old 06-19-2014, 02:46 PM   #5
lolife99
lolife99's Avatar
These Edelbrock tie rod sleeves are not sold as QA-1 brand.
5251 Heavy Duty Tie Rod Sleeve
5/8" diameter (63-70 tie rods)
total length is 4 7/8"
5252 Heavy Duty Tie Rod Sleeve
11/16" diameter (71-72 and 73-87 tie rods)
total length is 3-1/2"
Part #5250 is a GM car application.
5250 Heavy Duty Tie Rod Sleeve
5/8" diameter
total length is 3 3/8"
Application is:
•1964-70 GM A-Body
•1978-88 GM A-Body/G-Body
•1982-92 GM F-Body
•Short, 5/8''
Keith
Old 06-19-2014, 02:49 PM   #6
Coda O'Dell
Coda O'Dell's Avatar
I had the same question and porterbuilt sent me Part number 31001. They sell them at Oreillys for 5 bucks a pop.
Coda O'Dell is offline   Reply With Quote
Old 06-19-2014, 02:53 PM   #7
lolife99
lolife99's Avatar
Yep,... $5.97 at Summit Racing,...
http://www.summitracing.com/parts/rnb-31001
Keith
Old 06-19-2014, 02:53 PM   #8
1moretoy
5/8" diameter
Application is:
•1964-70 GM A-Body
•1982-92 GM F-Body
•Short, 5/8''
I'm using Mcgaughys 2-1/2 drop spindles.
Old 06-19-2014, 02:55 PM   #9
lolife99
lolife99's Avatar
The year of spindle, will determine the year of the tie rod sleeve and the tie rods.
What year spindles did you buy?
60-62
63-70
71-72
73-87
All take a different outer tie rod.
Keith
Old 06-19-2014, 02:59 PM   #10
lolife99
lolife99's Avatar
Here's a good picture of the lower shock stud.
Keith
Old 06-19-2014, 03:10 PM   #11
1moretoy
here's a good picture of the lower shock stud.
63-70
Old 06-19-2014, 05:37 PM   #12
Blackpony
Blackpony's Avatar
Does anyone know the thread pitch of the inner and outer tie rods on an 80's c10? I have been tossing around thw idea of using heim joints and building my own bump steer kit. Unless someone makes a bumpsteer kit I am not locating?
Blackpony is offline   Reply With Quote
Old 06-19-2014, 05:54 PM   #13
lolife99
lolife99's Avatar
Should be 11/16-24.
Keith
Old 06-19-2014, 07:06 PM   #14
Blackpony
Blackpony's Avatar
Excellent thanks!
