06-20-2014, 01:00 AM | #1 |
'62 dually, swapping out master cylinder
So the the hard line in the rear rusted out and brake pedal went to the floor while backing up in the driveway. I figured now was a good time to replace the one pot master cylinder with a two pot since I'll be bleeding the brakes anyways, any recommendations on what master cylinder to use?
06-20-2014, 01:26 AM | #2 |
Re: '62 dually, swapping out master cylinder
I'm doing the same next weekend. The master I plan on using is for a 90s chev truck and a wilwood propotioning valve. My truck has disc brakes tho, so I'm not sure how it would work on your truck.
06-21-2014, 10:07 PM | #3 |
chiefrocka did a write up on this and also gives master cyl numbers http://67-72chevytrucks.com/vboard/s...d.php?t=332148
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
06-22-2014, 12:50 AM | #4 |
60-66 Nut
I would use a master for a '67-'70 C30. You could also upgrade to power brakes if you desired.
09-12-2014, 08:46 PM | #5 |
Alright, finally getting around to this project on the '62 dually. Is there any reason I can't use the front suspension out of a '76 GMC? The donor truck uses 5 lug wheels.
09-12-2014, 11:15 PM | #6 |
You'd have a 1/2 ton front end and everything that goes with that. Why not just get a front end from a '71-'87 1 ton? I bought a '76 3/4 ton chassis for $200 the other day.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread 1968 Impala 4 door sedan (future driver project) thread Last edited by 66Submarine; 09-13-2014 at 12:03 PM. |
09-12-2014, 11:37 PM | #7 |
is the 3\4 ton basically a bolt on swap? I think the half ton is just a couple holes need to be drilled.
09-13-2014, 01:34 AM | #8 |
60-66 Nut
As I stated in my reply to your PM, the C20 or C30 front suspension will bolt to your '62 C30 frame that same as it would with a C10.
09-13-2014, 12:06 PM | #9 |
Yes, but my question is why you want to put a 1/2 ton front end on a 1 ton flatbed dually with 5.14 gears to begin with...I don't get it. BTW, I thought SRW for some reason earlier; get one from a dually so you don't have mismatched wheels.
09-14-2014, 12:12 AM | #10 |
The only reason for the half ton front end was because there's one for sale locally for a good price but I'm not considering that route anymore and will start looking for a 3\4 or one ton front end. So by going with the later model front end can I completely ditch the old hydro vac system?
