Drive shaft center support
![]() ![]() This part doesn't seem very well designed with the tack welds. I believe that's were it came apart. I plan to weld the one more thoroughly before replacing. Anyone else's break? |
Re: Drive shaft center support
Return that before you touch it go inline order the polyurethane aluminum cast on from any chev after markets best 100 bucks sent it the drive train
#3 | |
It sounds like you are talking about more than just the flange. Care to elaborate on what made the cast one so much better? |
I gave up on those a long time ago. I went with the good ones. No more tack welded sheet metal bracing.
