Old 06-20-2014, 01:17 PM   #1
John H.
John H.'s Avatar
7042911 Restored 1972 350 California 4spd
This is a 1972 Chevrolet 350 California Rochester quadrajet carb that will fit Chevy 327 and 350 engine quadrajet intake manifolds. The difference between this carb and the 49 state carb is an extra vac port that I believe goes to the airpump muffler assembly. This port is above the fuel line inlet. A thick insulator mounting gasket is provided for 1970 and later intakes.
This carb was done by the Carb doctor who has over 40 years experience rebuilding carburetors and has done thousands. This carb has just been restored and is ready to install. The rebuilding extras include NEW bronze bushings installed in base. ALL rebuilt quadrajets should have this done. The bases are aluminum and the shaft bores wear and cause poor idle and vacuum leaks. All NEW primary throttle plates are installed. They are also aluminum and wear out. The secondary air valve cams are plastic. This lifts the metering rods when the secondary’s open. They wear out or break causing a lean wide open. All NEW air valve cams are used in these rebuilds. New float installed. The main well fuel plugs are MT13 sealed. Other sealers will not hold up to today’s fuels and will leak. The accelerator pump cups are fluorelastomer and are blue in color. They are the only pump cups that will withstand today’s fuel additives. The black pump cups are no good and will swell or shrink. All NEW choke pulloffs. The secondary throttle plates are DAG213 sealed for a good quadrajet idle quality. The top and body are chemically color bond 420 dichromated.
The aluminum base is restored with a two part cleaning process that brings the aluminum back to the original finish. No silver paint or wire buffing is used. The bottom of base is then machined flat to prevent any potential warpage. The screws and linkage are yellow zinc plated. No rusty parts here. Carbs are tested on their machine that uses a pressure gauge and fuel meter. This assures no leaks and a good pump stream for the accelerator. A mounting gasket and an air cleaner gasket are included. You will not be disappointed.
7042911
Fedex Ground Shipping with INSURANCE is included.
$285 shipped to Conus
Name:  7042911 side choke.jpg
Name:  7042911 side 7042911.jpg
Name:  7042911 bottom.jpg
John H. is offline   Reply With Quote
Old 06-20-2014, 01:21 PM   #2
Coley
Coley's Avatar
Re: 7042911 Restored 1972 350 California 4spd
Wow....very nice and interestingly, the exact right carb for my (California) truck....hmmm.
If my original carb was not running great, I'd be all over this...hmm.
Again, very nice carb.
Did you buy it then not have an application for it? or go to an Edelbrock or Holley?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 06-20-2014, 01:47 PM   #3
John H.
John H.'s Avatar
I have had a number of carbs done by Bob over the years from quadrajets, 3x2 tri power setups for my GTO's. Most good cores are $50 so the rebuild is basically $225 and run fantastic. Shipping may be more to Canada
Just trying to share this resource with the board.
Old 06-21-2014, 09:34 AM   #4
John H.
John H.'s Avatar
Weekend bump for an offer.
Old 06-22-2014, 08:33 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
PM sent, I'll take it pending your reply.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 06-22-2014, 09:28 AM   #6
John H.
John H.'s Avatar
Sold to David pending payment.
Old 06-22-2014, 02:13 PM   #7
jimer1964
jimer1964's Avatar
Hey John, interested in one of these if you can come up with another! Thank you
jimer1964 is offline   Reply With Quote
Old 06-22-2014, 02:20 PM   #8
Sillyoldman
#16876
Sillyoldman's Avatar
John I have a Q-J needing some help. Is Carb Doc a local guy? Link? Thanks.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-22-2014, 08:29 PM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
PP sent... Thanks
Old 06-23-2014, 12:24 AM   #10
John H.
John H.'s Avatar
He is in Line Lexington, PA. Let me know if you need his contact info.
Old 06-23-2014, 12:25 AM   #11
John H.
John H.'s Avatar
Jimer1964: contact Bob Stone at classiccarb@aol.com
He may be able to help.
Old 06-23-2014, 07:55 AM   #12
jimer1964
jimer1964's Avatar
Thanks for the info!
Old 06-23-2014, 11:42 AM   #13
D.PASSMORE
One of the First
D.PASSMORE's Avatar
FYI, I dealt with Bob a few times, great guy. But, realize that he will build the carbs back to spec for a stock Chevy engine. If you are looking to create more HP by adding different items onto the motor, there is a high possibility that the carb will need to be adjusted with different Jets and/or the rods in order to meet your motors A/F (Air / Fuel) ratio for peak performance.
I had to do that on the last carb that I got form him, it purrs very well and runs like a scared jack rabbit - no problems.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 06-23-2014, 05:40 PM   #14
Sillyoldman
#16876
Right on thanks for the info guys!
