coils are not firing...need help
so I talked to my buddy today and he says that he went through the wiring and checked everything and the pcm is not letting the coils for cylinders 2,4,6 and 8 fire. could this have anything to do with the pcm reflash or could the pcm be messed up somehow? everything else is fine....the other coils and injectors etc are working as they should.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
Boosted Member
Re: coils are not firing...need help
Make sure the coil connector for that bank is plugged in...and make sure it's getting power. Nothing in the flash would cause this.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
its all plugged in and getting power but just not firing
If it's only 2/4/6/8 I highly doubt it's the flash. You either have a bad ecu (bad transistors/connections) or bad wiring.
Stupid checks: Swap the 1/3/5/7 and the 2/4/6/8 coils see if the problem persist, or if it swaps sides. If you can get your hands on an o-scope check the signal wire into the coil. If you're losing 1/2 the motor I feel like it has to be at the distribution block. |
meowMEOWmeowMEOW
corrupted injector drivers can cause random ass problems, especially if the ecm was flashed to a non-standard driver.
You could also have a physical restriction in the rail, but its tough to get one that locks up one whole bank. From the blue connector: 4 LT GRN/BLK 1745 Fuel Injector 2 Control 44 LT BLU/BLK 844 Fuel Injector 4 Control 37 YEL/BLK 846 Fuel Injector 6 Control 77 DK BLU/WHT 878 Fuel Injector 8 Control
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Boosted Member
What is a non-standard driver, and how do you flash one in?
#7 | |
meowMEOWmeowMEOW
The injector driver is the part of the PCM that controls injector pulse. The PCM is setup to control a certain impedance of injectors, but aftermarket "Boxes" and wiring can be hooked up. IF you hook up a set of injectors in the wrong impedance, you can fry the PCM board (internal short). The other half was supposed to be; was different injector scaling flashed in? Thanks for keeping me honest Wasted.
Yea my buddy said that driver is whats not letting the coil fire...i emailed brendan and he replied...heres the reply....
make sure o2 sensors are not crossed up. 4 wires going to each sensor (check connector for the o2, harness side.) Should be a purple wire in the bunch, drivers side should be purple white stripe, passenger side solid purple no stripe. If these were backward, it could have fouled the spark plugs causing a miss on one side of the motor once the fuel trims went crazy. If they are backward, you will have to reset fuel trim with scanner, or unplug pcm for a few hours...
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) Last edited by ivorton74; 06-20-2014 at 06:40 PM. |
meowMEOWmeowMEOW
You can unplug both 02's and the MAF and force OLSD, which tries to command straight off the VE table with no other inputs. Don't drive it like that on a stock tune, but you can try it, to see if bypassing the 02's helps you. I don't see how the 02's would stop a whole bank from firing, but you can try.
You can also try grounding the case of the pcm straight to the block/heads to see if you have any of the internal grounds fried. Injectors fire off of Ground on these motors, and have a constant +12v supply iirc.
thanks guys...ill let him know what u guys suggested and see what he finds
#11 | |
Boosted Member
Well turns out there was a loose ground wire....the coils are all firing now but the MAF sensor is dead so have to get a new one
#13 |
i believe i read somewhere on here someone else having a issue with the maf sensor as well, did you check both grounds on the back of the motor? not saying it'll fix it but worth a shot
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#14 |
Yeah all the grounds are good.
