Old 06-20-2014, 03:54 PM   #1
gmebey
Complete front end rebuild kits
I'm have driven myself crazy researching for the most complete front end rebuild kit for a 1969 C10 P/U. My project truck is in need of about everything in the front....maybe even springs.
I would love to find the rare Moog kit that is made in the USA, but it seems that if a thing of the past with corporate America going to cheap labor....Chinese made.
Has anyone used a kit from "a-resto-parts.com"? Is it good quality?
gmebey is offline   Reply With Quote
Old 06-20-2014, 04:00 PM   #2
wgeyer88
Re: Complete front end rebuild kits
The ECE kit is all Moog components:
http://www.earlyclassic.com/catalog.aspx
I pieced my parts together from rock auto, using the ECE as a guide. It probably saved me 50%, they always have a few of the parts on closeout for pennies on the dollar.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 06-20-2014, 04:06 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I put in piles of Moog parts on different trucks and pretty much buy all of them from Rockauto or Amazon.com. And I have yet to see one that wasn't made in USA.
No real kit needed, just piece it together.
2 upper ball joint
2 lower ball joint
2 upper control arm shaft kits
2 lower control arm shaft kits
2 inner tie rod ends
2 outer tie rod ends
1 pitman arm
1 idler arm
2 tie rod adjust sleeves
1 pair lower control arm bump stops
1 pair of upper control arm bump stops
2 pairs of sway bar bushings if your truck has a sway bar
Add in a pair of shock absorbers of whatever flavor you prefer and a pair of coil springs and you've covered your bases.
Old 06-20-2014, 04:14 PM   #4
badd71
Active Member
Dont forget Summit. Free shipping over $100 and they carry Moog.
badd71 is offline   Reply With Quote
Old 06-21-2014, 03:10 AM   #5
RManson
One thing to consider. If you're planning on replacing the control arm bushings and will need to pay someone to press them out and back in, price a new set of tubular arms. They come oreassembled with ball joints and could be a better deal in the long run with a performance upgrade to boot. FYI
RManson is offline   Reply With Quote
Old 06-21-2014, 06:36 AM   #6
Tx Firefighter
There shouldn't be any pressing needed on the control arm bushings.
Old 10-10-2014, 11:51 PM   #7
gmebey
After a few emails and a phone call I decided to go with the kit from http://stores.a-resto-parts.com.
The kit looks great, and so far all has been going together without any issue. They "hand pick" their suppliers based on the constant changing quality of suppliers.
There was small issue with the kit that they quickly took care of and in today's lack of good customer service/support it was great to experience great customer service!
Old 10-11-2014, 01:46 AM   #8
rc32187
rc32187's Avatar
I picked my moog front end kit up here. http://www.moog-suspension-parts.com/ Fast shipping and everything went together real well and seemed to be of good quality.
rc32187 is offline   Reply With Quote
Old 05-11-2021, 03:40 PM   #9
Spalma916
I’m also trying to find the best kit with the most pieces, I’d like to replenish it all in one shot so I’m going to try aresto kit, it has 17pc compared to mooms which is 10pc. Only one question, did you need a press?
Spalma916 is offline   Reply With Quote
Old 05-11-2021, 04:20 PM   #10
Big Kev-O
Big Kev-O's Avatar
Yes, you will need a ball joint press to remove and install the ball joints in the lower control arms. The upper ball joints are riveted in from the factory. You drill the rivets out and the new ball joint installs with bolts. I borrowed the ball joint press tool from Oreilly Auto Parts to do mine. There are "How To" videos on youtube.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 05-11-2021, 05:12 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
7 year old thread... lol
You can get all the parts to rebuild a front end on these trucks at almost any parts store. Just ask for Moog parts. No need for mail order. I got all the parts I needed (including the balljoint press rental) for under $250 bucks.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-11-2021, 05:35 PM   #12
lil hoodlum
lil hoodlum's Avatar
Gary
I agree with Gary about using Moog parts and getting them at your local parts place, however, my experience has been that summit racing or the like is way cheaper than my AutoZone or O'reilieys auto parts store.
lil hoodlum is offline   Reply With Quote
Old 05-11-2021, 07:54 PM   #13
Spalma916
Hahaha, didn’t even notice the date but excellent info! Thanks guys
