Old 06-20-2014, 07:03 PM   #1
that_ry_guy
POR 15 Top Coat
Its Friday evening and the POR 15 info line is closed for the weekend so I figured I would post here in the hopes that someone might be able to shed some light on my question.
My frame is painted with POR 15 rust preventative coating. I have scuffed it up with a maroon scotch brite pad. I had ordered the POR 15 self etching primer and the Chassiscoat Black. When my shipment arrived today the Chassiscoat black had been replaced with a product called "Top Coat". Chassiscoat Black has been discontinued. According to the can I can paint it right over the rust preventative coat. Apparently no need for primer? Does this sound right? Would you use the self etching primer anyway and then put the "top coat" over it or is that overkill?
Anyone familiar with this new "Top Coat" product?
that_ry_guy is offline   Reply With Quote
Old 06-20-2014, 09:21 PM   #2
hubba033
hubba033's Avatar
Re: POR 15 Top Coat
im pretty sure you jus want to topcoat over the POR15. you shouldnt need the self etch primer.
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt
01 Pontiac Trans Am WS6
hubba033 is offline   Reply With Quote
Old 06-20-2014, 10:32 PM   #3
hotrodder
Re: POR 15 Top Coat
it is correct no need for the self etch with the new updated topcoat. I work at a automotive paint store that sells por-15, and the newer version is a great product.
hotrodder is offline   Reply With Quote
Old 06-21-2014, 12:40 PM   #4
that_ry_guy
Re: POR 15 Top Coat
Thanks for the replies. Sounds like a great product. I'll attempt to return the self-etching primer this week.
