Old 06-21-2014, 01:41 AM   #1
Money_pit
Money_pit's Avatar
Engine mount headaches
Hey everyone newbie here I just got finished installing the 73-87 engine stands in my 71 lwb. My problem is that now my trans is hitting cab floor. Also just replaced all the cab and core support bushings. Truck was originally equipped with 350 and a th350 I'm swapping in a fresh 327 and fresh th350. Just wanted the more modern clamshell mount now I'm debating going back to the original mounts any suggestions greatly appreciated sorry no sig yet
Money_pit is offline   Reply With Quote
Old 06-21-2014, 05:32 AM   #2
Xeen
Xeen's Avatar
Re: Engine mount headaches
Welcome to the board.
I am unfamiliar with the 73-87 engine stands so unfortunately I don't know if those change the resting height of the engine or not.
There are a bunch of guys on here that will know though so hopefully one of them stops by.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-21-2014, 09:21 AM   #3
GSFMECH
On the road
GSFMECH's Avatar
They can be made to work but they do make the engine sit higher. A lot of guys use them for big block swaps but they do sit make the engine sit much higher than stock. There is nothing wrong with the original mounts, and everything will work right, including fan clearance on your shroud etc. Do you still have the original trans crossmember?
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 06-21-2014, 11:52 AM   #4
Money_pit
Money_pit's Avatar
Yeah Im trying to use the original crossmember. There will have to be new holes drilled in frame in order to use that crossmember.
Also wondering if anyone has used the tubular engine stands? That's my next option. Again thanks for any suggestions
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Old 06-21-2014, 02:48 PM   #5
Xeen
Xeen's Avatar
Which tubular engine stands, the ones from CPP?
If so CPP has a new sheet metal version that is better because it's lower profile and allows more room for exhaust manifolds and headers.
Go to Ebay and check them out, here is a link.
With mounts.
http://www.ebay.com/itm/1963-66-68-6...item417bd53146
Without mounts.
http://www.ebay.com/itm/1963-66-68-6...item3cdb799fba
Old 06-21-2014, 03:10 PM   #6
Money_pit
Money_pit's Avatar
Thanks Brian I haven't seen those mounts but I'm pretty sure that's what I want they look really solid. Going to order a set will post a review upon arrival thanks again
Old 07-14-2014, 08:48 PM   #7
Money_pit
Money_pit's Avatar
Little update order placed to cpp for mounts. Hopefully I get them before the weekend let you guys know what happens
Old 07-15-2014, 03:40 AM   #8
Xeen
Xeen's Avatar
The sheet metal engine stands are very nice you will really like them.
Old 07-15-2014, 05:16 AM   #9
JointTech
JointTech's Avatar
nice friends. mine smoke all my stuff and leave a mess in my shop They do lift heavy things from time to time though.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-19-2014, 10:41 PM   #10
Money_pit
Money_pit's Avatar
Well just got the cpp sheetmetal mounts installed.
They look really good. I'll try to get some pics up in the morning.
