Would S10 rotors fit on C10 spindles?
I already have my wheels, but when I put the drop spindles on the front, the tire will rub on the fender. The wheels have the 5x4.75 pattern, so I have
1.25" adapters on them and it just pushes them out a little too far. Would any front rotors from an S10, camaro or any other 5x4.75 pattern fit on a set of drop spindles for a 84 C10? Or would it be cheaper to have the rotors drilled and new studs put in for that pattern? Thanks |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Would S10 rotors fit on C10 spindles?
This has been addressed before.
There is a couple of options. Re-drill would be the cheapest. The other option is s little more complicated. Use the following parts: 1) 73-87 Light Duty spindles for 1" rotors 2) 1992 Camaro 1LE rotors 3) 73-87 Calipers and bearings for Light Duty rotors. The second option is a good choice if you are adding drop spindles. Your truck may already have the light duty rotors. DO you know your current rotor width?
Thanks for the info. I found some old threads by searching Bing. I do have the light duty spindles, rotors and everything else. I just bought the 1LE Camaro rotors and will be getting drop spindles very soon as well. Thanks
You can use the camaro rotors with your factory truck spindles, or your truck drop spindles.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
