08-04-2003, 01:57 AM | #1 |
700r4 users
For those of you who have put a 700r4 with a quadrajet, what tv cable mount did you use?
Thanks Jason |
08-04-2003, 06:01 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
When I was carburated I used one from Jeg's or Summit
here is the ad in summits site. http://store.summitracing.com/defaul...+cable+bracket
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
08-04-2003, 08:09 AM | #3 |
Watch out for your cornhole !
Any mid 80s Chevy truck with a Q-jet and 700 should work. There a billions of them in the junkyards. Just look for a pre 87 (EFI) truck with the overdrive PRNDLL thing on the dash.
08-04-2003, 09:36 AM | #4 |
Bobby what do you use now with the TPI?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-04-2003, 10:43 AM | #5 |
I got a thing from Bowtie Overdrives that adapted my carb to work with the TV cable. Has to have the right linkage on the carb though...
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
08-04-2003, 11:11 AM | #6 |
How do I tell if my carb has the right linkage or not?
08-04-2003, 11:28 AM | #7 |
boneyard time
go to the bone yard......look for an early 80's chevy sedans and wagons I find great parts on the capriece and malibu's and ofton the chevy vans
08-04-2003, 01:20 PM | #8 |
The one in BobbyK's post is the one I'm using with my QJet... I think I got mine from Summit...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
08-04-2003, 03:23 PM | #9 |
So would anything from a rear wheel drive and quadrajet work? As long as it was a 700 or 200 trans?
08-04-2003, 06:41 PM | #10 |
Custom 68
I use the stock mount that comes on the TPI air plenum.
08-04-2003, 09:02 PM | #11 |
I used TV cable P/N 25515598 and Bracket P/N 22504927. Bracket has cutouts for Accel. cable and TV cable. Looks factory.
Both are available from GM . Bracket mounts to two rear bolts on Carb.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
