Necessary to take off hood for heater box removal?
Trying to get the heater box out of my 72 and don't see any other way then to remove hood. Should I continue to remove hood or is their a trick I'm missing? I'm nervousness about it not lining back up if I remove it. Non AC.
Re: Necessary to take off hood for heater box removal?
I'm pretty sure you have to. I had to remove my hood hinge to access one of the bolts on my 67. And if it's not necessary it makes it a whole lot easier
If you do have to remove the hood, drill tiny 1/8" holes through the hinge and into the hood (in a place you can't see much). Then when you go to put it back, you can stick an awl through the hole to align the hood to the hinges.
Pretty much you have to remove the hood. An oh yeah you might have to drop the inner fender too.
I had a much easier time with the hood off and the fender out of the way.
I've pulled the heater box out of my 72 and my 69 with removing anything other than the bolts holding it on. Mine came right out with no issues at all. Didn't have to remove the hood or losen the fender at all.
http://smg.photobucket.com/albums/v655/aaronhero/ |
On my 70 I got away with dropping the pass side inner fender liner....its a bear, especially if youre hands arw big.
![]() Join Date: Sep 2009
this was my experience as well
But the best quality heater core you can. I should have had my factory one rebuilt, the one I got from LMC is cheaply made. Maybe NAPA has better stuff. But it's sure not a repair I'd like to make too often.
Also the new one I got was less substantial than the original so I had to "shim" it or pad it with wedges so it didn't rattle or move inside the heater box.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I work alone so pulling a hood is a pain for me. I usually just prop the hood up with a prop rod of some kind and fold a blanket up and shove it between the cowl and hood, then remove the hinge. The prop rod holds the hinge up and the blanket protects the paint on the hood edge.
#11 | |
I just removed the heater box/Habi-trail from my 70 gmc today, comes right out just remove the bolts and screws from both sides, then stick your hand behind the hood hinge and push the heater box straight towards the driver side, It will slide right out.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
