Old 06-22-2014, 01:12 PM   #1
jd21476
jd21476's Avatar
Rear window locking corner tabs.... Help
So I replaced my rear window locking strips with a new chrome one but I can't seem to get the corners at the bottom of the window to fit in.
Is there a secret to doing this?
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 06-22-2014, 01:18 PM   #2
Sodell
Sodell's Avatar
Re: Rear window locking corner tabs.... Help
Are you talking about the aluminum corner strips?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 06-22-2014, 01:50 PM   #3
jd21476
jd21476's Avatar
Yes
1973 Chevy K20
Old 06-22-2014, 10:04 PM   #4
Sodell
Sodell's Avatar
I use some soapy water and bend the tabs just a bit, then flatten it out as you press it in. You need a plastic tool to help with it. Also make sure your locking strips are not tool long, you just need a bit to go under the locking tab. They are a pain.
Scott
