Old 06-22-2014, 05:23 PM   #1
dawj11
turbo 350 lock up wiring?
I have a 1985 chevy 305 with a th350. the lock up converter has 2 wires a geen and tan how do I wire them to a rocker switch? I tried to wire it up but keeps blowing fuse is there a + & ground or just one power and one not used? Its in a streetrod not a regular chevy truck.
dawj11 is offline   Reply With Quote
Old 06-22-2014, 07:51 PM   #2
bnoon
Re: turbo 350 lock up wiring?
The TH350C is a rare bird. On my 86, I had one, and I had to troubleshoot the wiring for lockup. I ended uphaving a bad brake switch feed to the relay, so lockup never let go at a stop until the ig.ition was killed and restarted.
Did you bypass the relay and you are now wiring from a manual switch direct to the transmission leads? I believe mine was black with tan stripe on ground. Can't remember the other color.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 06-22-2014, 07:59 PM   #3
dawj11
I just have the wire on tranny wiring it direct to toggle switch
