06-22-2014, 07:26 PM | #1 |
Filler Neck - Beware "NOS"
Below are two shots of my 1970 filler neck. The installed one is the original which I did my best to restore. The second is a photo comparing it to the "NOS" one I bought off eBay.
As you can see, they're significantly different, and the "NOS" one would have left a fair bit of the ugly neck exposed. Note the package has bar code, which I doubt GM used in 67-72. So I think this is a case not unlike the door handle debacle. Probably GM had some offshore manufacturer crank out a bunch of service parts for these trucks in the mid 70s or early 80s, and they're just not the same as the originals. So they're all technical NOS, just remember the O doesn't mean "made when your truck was" or "same as what your truck came with".
06-22-2014, 07:46 PM | #2 |
2WD Jimmy
Re: Filler Neck - Beware "NOS"
Then that would be Genuine GM... Not NOS.
06-22-2014, 07:57 PM | #3 |
Well, it's both. Genuine GM and sitting on a GM shelf makes it NOS. You and I and most people would assume NOS means manufactured at the time of the vehicle production, but that's not explicit. And old factory part that's still new, no matter when it was made, could be called "NOS" without deceit - but I'd prefer disclosure that it's an 80s part different from the original run.
I thought about setting up a website where people could list their NOS parts and make it easier to search than eBay, but eBay is so dominant I doubt it'd pan out. As I was planning it though I registered the domain name NOSExchange.com Sadly, that's the same spelling as "No Sex Change".
06-22-2014, 09:08 PM | #4 |
Moderator
Those look like two different seals...one is for 67-70 filler neck, the other is for 71-72
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-22-2014, 09:25 PM | #5 |
Yeap, different year rubber filler necks.
06-22-2014, 09:29 PM | #6 |
06-22-2014, 09:30 PM | #7 |
The grommet on the right is exactly like the one that I removed from my 69. I am 100% sure it was the original. So, if that is the "NOS" one, it is correct for your 70 also. I replaced the original with the part number on the package pictured. Almost exactly 1" of the filler next is left exposed.
06-22-2014, 09:58 PM | #8 | |
Since the term NOS means New Old Stock it is ridiculous to believe that a part containing a bar code can actually be New Old Stock for a vehicle built in 1970. It could, however be a replacement, genuine GM part, manufactured between 1981 1nd now by any one of GM's offshore suppliers under contract to GM. |
06-22-2014, 10:05 PM | #9 |
Roadtrip!
I would agree with this...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-22-2014, 10:45 PM | #10 | |
06-22-2014, 10:58 PM | #11 |
I still have some of the "NOS" grommets you show that I bought from Chevrolet years ago.
I never used them because they didn't look like my 72. Does anybody remember when GM did a run of Chevy "Tailgate Appliques" with painted plastic letters? I still have one of those too.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
06-22-2014, 11:33 PM | #12 |
The last one I bought for my 72 seemed to rot pretty quick. Are the NOS ones better in that regard?
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
06-23-2014, 01:44 AM | #13 | |
Moderator
06-23-2014, 02:23 AM | #14 | |
I make the differentiation between parts made between 67-72 for these specific years of truck. I think it matters - when and where. Similarly if a 1959 apache napco nos part had a bar code one would think something is fishy. It's safe to assume that bar code parts were not made in the USA. Maybe mexico, maybe not. Maybe inferior, maybe not. Does anybody have a picture of a bar code tail light part made by guide for GM and the plastic package unopened? Does it say "guide 67"? just curious Of course I use repoop stuff because its a truck and I'm not repainting the Monalisa FWIW
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
06-23-2014, 09:11 AM | #15 |
Curious why you say that? Are you saying no GM parts that have barcoded boxes are made in USA?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-05-2014, 02:24 AM | #16 | |
Definativy, I have no proof but it is what I suspect.
07-05-2014, 02:30 AM | #17 |
The Chevy dealer sold me one of those wrong fuel tank grommets for my '68, back in the '80s. Swore up and down it was the right style. Didn't need to use it until about 9 years ago. Then it tore an edge. Still on there because I'm too lazy to pull out my seat-back tank to get at it.
07-05-2014, 12:26 PM | #18 |
Moderator
You don't need to pull your tank to install or remove the filler neck grommet.
