2-yr build for my 13-yr old (1968 C-10 SWB fleetside)
Always wanted to build one of the 67-72 SWB fleetside trucks and when my 13 yr old son said he was interested as well I decided to go get one. I did not pay very much and I didn't get very much as well. Hope I can put it in nice, safe, dependable driving condition before he hits 16 yrs old.
![]() Join Date: Jul 2007
Re: 2-yr build for my 13-yr old (1968 C-10 SWB fleetside)
Nice starting point.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
We got the front clip removed and found a few surprises. Looks like it was hit in front drivers side corner, not so bad. Rusted where bottom rear of fender bolts to cab, guess this is fairly common. Can I get replacement sheetmetal for that area? Where is the best place to get the sheetmetal parts like rockers and floorpan sections? Also noticed a strange upward bend in the frame on the passsenger side. Anyone know why the frame would be bent there and how does a guy go about fixing that? See pics.
You can get the cab metal from most of the usual vendors, classic, lmc, brothers, GMCPaul, Jim Carter, Ron Manes. The turned up lip is factory. No one knows why. Torch it and beat it flat if it bugs you. Leave it if you're going LS, some guys use it to their advantage dealing with AC lines. Good luck!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#5 | |
Still Learning
Looks like a pretty solid start. Two year build is ambitious. Looking forward to following along. Welcome to the forum BTW.
![]() Join Date: Jul 2009
I'm watching... 2 years is a great timeframe, but you better get to work
![]() Join Date: Dec 2012
Looks like a great start to me, appears you have all the body panels. I think two years is a great goal and maybe with your sons help you will be able to achieve that. Good luck and welcome!
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
![]() Join Date: Aug 2007
Two years? No problem. From start to finish me and my two boys finished our truck in less than one year, you will have her done in no time.
Scotts72C10 |
Hey Neal64ss, glad to see you got the build thread going. Was going to say that lip helps to keep the AC lines from hitting the frame. Also allows wrench room. Truck looks nice. Good start for a project. I got most of my panels from Banana something or other. Triplus parts. Most we're good quality. Don't get the bed floor repair panel, nowhere near matching oe. Everything else was close enough to make work. There's a nice crate LS3 in the adds section. Just what a 16 year old boy needs. Good luck. Jim
#11 | |
#12 | |
You are going to enjoy this truck just as much as he will they are a lot of fun. Tabco makes some of the best fitting replacement panels and patch panels and they are made in the USA , no matter where you buy the patch panels make sure you get the direct replacement version not the slip on version because there are both types available, Tabco indicates the difference on their website but unfortunately most others don't so be careful when ordering. http://www.tabcobodyparts.com/ One other thing, don't forget to have fun and cherish the one on one time because as you know they grow up way too fast and are gone before you know what happened. Last edited by Xeen; 06-28-2014 at 10:18 AM. |
#13 | |
#14 |
Update time. Been busy last few monthsbut trying to get back to work on the 68 truck. Found a frame on craigslist. It had 5 lug discs and rear, which I was planning to change anyhow and it is straight, so I bought it. Got it stripped down and plan to flip the rear trailing arm brackets, install bolt in c notch, and sandblast it in the next week. Will then give it a couple coats of rust encapsulator and a couple coats of chassis black.
#15 |
#16 |
Nice update, looks like a good score, and one step forward. Keep us updated and remember to have fun with the kiddo.
#17 |
Still Learning
Nice looking frame. Craigslist scores are good
#18 |
![]() Join Date: Aug 2012
good luck there man. At least you have some help. Grab hold and enjoy the ride.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
#19 |
Working today at installing c-notches. I hate rivets. Took out about 20 a week or two ago and thought I had developed a winning method (Dremel & air chisel). Currently am stuck trying to get the two rivets out where the coil spring mounts. Got the c-notch section cut out but the rivets are kicking my butt.
#20 |
I like drilling the head out till it falls off then punching the rest out with a hammer and punch. Any pics?
#21 |
Drilling rivets sucks. Quickest way I've found so far is to use a flap disc like these:
http://www.ebay.com/itm/WEILER-50603...item4874fa21ff With a 4" grinder it takes about 90 seconds to grind the whole rivet head off. Then just use a punch to knock the rest out. Looks like a great project!
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
#22 |
Got the c-notches installed. My new method for removing rivets is cut head longways with cutoff wheel, air chisel to remove head, punch out if possible, drill out if it will not punch out. Now to get this frame painted.
#23 |
Got frame painted over the weekend. Used rust encapsulator and chasis black from eastwood. Put both on with brush. Rust encapsulator went on great and easy. Chassis black went on OK but if I had to do it over again I would have sprayed it instead of using a brush. Just the frame, so I am happy with the result. Big milestone in the build to now have the frame done and ready to start on the suspension.
#24 |
Looking good. Its amazing what a coat of paint can do.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#25 |
Looking good! Wait til it rolls. That is a great feeling. Warm weather will be here soon enough. That's much more fun when it's nice out. GO HOGS! Saw your little razorback sticker.
