Old 06-23-2014, 03:29 AM   #1
Tuff 1986
Tuff 1986's Avatar
A/C and Ashtray help..
Hopeing someone can help me out here with a couple of questions that I have.. My A/C is working fine but the two hoses that connect to the condenser and the compressor one of the hoses is really hot to the touch and the other is not I am wondering if this is normal or is there something that needs to be repaired?? My other question is how do I install an ashtray?? I tried removing one from the salvage yard with no results.. So I bought one on eBay and need help on how to install it..
Will I ever finish my 1986 stepper..
Tuff 1986 is offline   Reply With Quote
Old 06-23-2014, 08:40 AM   #2
jjzepplin
jjzepplin's Avatar
Re: A/C and Ashtray help..
If your a/c is working don't fool with it. One line will be hot (removing heat) and the other will be colder. All is good.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-23-2014, 06:44 PM   #3
Dsquared
to remove the ash tray, remove the glovebox,the airduct to the drivers side lower vent, then remove the box that connects the vents to the air box. take out screws in ash tray, close it , push it in the dash,turn it and pull it out. don't forget to unplug the lighter
Dsquared is offline   Reply With Quote
Old 06-24-2014, 03:47 AM   #4
Tuff 1986
Tuff 1986's Avatar
Thanks for your help guys..
Old 06-27-2014, 02:26 PM   #5
misternash2
i just typed about two pages worth of a/c information...and it got lost somewhere in cyberland.
i'll make a new post.
misternash2 is offline   Reply With Quote
Old 06-29-2014, 02:56 AM   #6
Tuff 1986
Tuff 1986's Avatar
I have searched for previous post but could not find one that says if I can splice the cig. Lighter into the light that turns on when the door opens.. Light is located underneath the glove box.. Or does anyone know of an easier way I can get my cig. Lighter to work? What other wire can I splice into..
Old 06-29-2014, 07:44 AM   #7
Desert1957
Desert1957's Avatar
I'm pretty sure the Cig lighter circuit (hot and ground) goes directly back to the fuse box. Due to the amp load I would not splice it into any other existing circuit.
Desert
Desert1957 is offline   Reply With Quote
Old 06-29-2014, 08:41 AM   #8
jjzepplin
jjzepplin's Avatar
Originally Posted by desert1957 View Post
i'm pretty sure the cig lighter circuit (hot and ground) goes directly back to the fuse box. Due to the amp load i would not splice it into any other existing circuit.
Desert
this
Old 06-30-2014, 02:24 AM   #9
Tuff 1986
Tuff 1986's Avatar
Thanks guys.. I will check tomorrow and see if I can trace the wire for the lighter from the fuse box..
