Old 06-23-2014, 09:19 AM   #1
DT1
DT1's Avatar
TH350 Leaking
My TH350 has always leaked a just tiny bit, but this weekend I noticed the leak became noticeably bigger. After a thorough inspection, I'm relatively sure it's the pan gasket (Again). I removed the torque converter cover and it's dry as a bone in there and there are no signs of leaking from the filler tube or anything higher than the pan. This has been reoccurring problem for a few years now so I think I'm, going to go a different route. I'm thinking of replacing the stock pan with an aluminum one and also install a Moroso rubber with steel core gasket. The pan I'm looking at is made by Mota Performance. It's very similar to a Mr Gasket pan . I'm not familiar with Mota and would like some input on the quality. Any other advice as to seal or not to seal would be appreciated too.
DT1 is offline   Reply With Quote
Old 06-23-2014, 09:31 AM   #2
geezer#99
geezer#99's Avatar
Re: TH350 Leaking
I had a leak like that. Thought it was the pan too. Changed it twice.
It was the shifter arm seal.
Old 06-23-2014, 10:16 AM   #3
DT1
DT1's Avatar
Re: TH350 Leaking
I know what you mean. Usually when you think you have it nailed, it turns out to be something else (Especially in the case of leaks). In this case I inspected around the shift linkage, modulator, fill tube, speedometer cable, and both front/rear seals and don't see any leaking. The only way I will be certain I to replace the pan gasket and keep an eye on it.
Old 06-23-2014, 10:23 AM   #4
geezer#99
geezer#99's Avatar
Re: TH350 Leaking
Mine kept coming back. Finally found it by tieing a narrow piece of cloth around the shifter arm right close to the case.
Old 06-23-2014, 12:03 PM   #5
Hugh Mongus
Re: TH350 Leaking
I took mine in last week to have a trans-go kit put in it. It was leaving a mess in my shop, so I told him to seal the leaks too while he had it. $500 later he had to replace the pan seal, shift arm seal, and the seal where the speedo cable goes in. He saved the old seals and showed me why they were leaking. They were all hard. All the pliability of the rubber was gone.
If I were you I would buy these seals and put them in yourself. I doubt they are that difficult, and it would save you a few dollars.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 06-23-2014, 01:45 PM   #6
geezer#99
geezer#99's Avatar
Re: TH350 Leaking
While you can install the shifter seal yourself, you need a tool (100 bucks) to remove it without scratching the bore that the seal sits in. Someone tried that on mine. Shifter shaft had to be re-machined so a new seal would work.
250 bucks later no more leak.
The pan gasket and speedo gasket are easier.
Old 06-23-2014, 03:30 PM   #7
DT1
DT1's Avatar
Re: TH350 Leaking
I would normally do that but I had the transmission completely rebuild less than two years ago.
Old 08-20-2014, 11:12 AM   #8
sKnNyPpY
sKnNyPpY's Avatar
Re: TH350 Leaking
I got the shift shaft seal removal tool from Napa for $7. Worked like a charm removing it except I bought the wrong replacement seal. Model #BK 7769250
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 08-20-2014, 01:26 PM   #9
MARKDTN
Re: TH350 Leaking
If your TH350 has an aluminum "bullet" for the speedometer driven gear, they are bad to leak. The replacement is steel and lasts much longer.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-23-2014, 12:45 AM   #10
MagmaJct
MagmaJct's Avatar
Re: TH350 Leaking
sKnNyPpY,
Got a part number for that tool? My TH350 leaks a lot too. I've just replaced the gasket and haven't put new fluid in it yet. Seems like a good time to replace this seal as well.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 08-24-2014, 10:10 PM   #11
sKnNyPpY
sKnNyPpY's Avatar
Re: TH350 Leaking
The bk# is the Napa part number for the tool. I don't have the number for the seal, the one from Napa I got was wrong so I got it from Transtar locally. Seal was $2. Took me 15 minutes to replace.
Old 08-24-2014, 10:11 PM   #12
sKnNyPpY
sKnNyPpY's Avatar
Re: TH350 Leaking
Transtar also had the steel speedo bullet for $7
Old 08-24-2014, 10:29 PM   #13
Thebrownturd
Re: TH350 Leaking
could be a warped pan
Thebrownturd is offline   Reply With Quote
